MLWizard stopped working "FileNotFoundException"
So a few days ago I installed the Rapidminer MLWizard extension. Upon installing it I tested it and it worked fine, now a few days later I am no longer able to use the wizard as it throws an "FileNotFoundException". I am getting the error when clicking settings->Automatic System Construction.
The log posts the following:
Jun 5, 2020 8:11:10 PM WARNING: Cannot initialize XML serialization. Probably the libraries xstream.jar and xpp.jar were not provided. XML serialization will not work! Jun 5, 2020 8:11:10 PM WARNING: Cannot read object from XML serialization. Probably the libraries 'xstream.jar' and 'xpp.jar' were not provided.
