Transform table to result view
Hi i have table in this below form.
How can i transform same into result view like below:
description |
Category |
count |
Z |
Available |
27.0 |
Z | Not Available | 14169.0 |
Z | Less Available | 863.0 |
Y | Available | 50.0 |
Y | Not Available | 58971.0 |
Y | Less Available | 888.0 |
OTHER | Available | 380.0 |
OTHER | Not Available | 272343.0 |
OTHER | Less Available | 3231.0 |
X | Available | 1564.0 |
X | Not Available | 1313.0 |
X | Less Available | 3087.0 |
description |
Avaialble |
Less Available |
Not Available |
X |
1,564 | 3,087 | 1,313 |
Y | 50 | 888 | 58,971 |
Z | 27 | 863 | 14,169 |
OTHER | 380 | 3,231 | 272,343 |
1 - 11 of
111
@hbajpai - I was trying pivot but it is asking one of aggregation . but i need the same value to be transposed and cant leave aggregation empty.
According to you i should use pivot operator
step1. Groupby attribute - description and cateogry
aggregation - sum over count..
I tried but it is not giving me desired result.
Hey @pallav
I tired it on my end and it does work. Check out the XML.
<?xml version="1.0" encoding="UTF-8"?><process version="9.7.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="utility:create_exampleset" compatibility="9.7.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="34"> <parameter key="generator_type" value="comma separated text"/> <parameter key="number_of_examples" value="100"/> <parameter key="use_stepsize" value="false"/> <list key="function_descriptions"/> <parameter key="add_id_attribute" value="false"/> <list key="numeric_series_configuration"/> <list key="date_series_configuration"/> <list key="date_series_configuration (interval)"/> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="input_csv_text" value="description, Category, count Z, Available,27.0 Z,Not Available , 	14169.0 Z,	Less Available	,863.0 Y,	Available	,50.0 Y,	Not Available	,58971.0 Y,	Less Available,	888.0 OTHER,	Available,	380.0 OTHER,	Not Available,	272343.0 OTHER,	Less Available,	3231.0 X,	Available,	1564.0 X,	Not Available, 1313.0 X,Less Available,	3087.0 "/> <parameter key="column_separator" value=","/> <parameter key="parse_all_as_nominal" value="false"/> <parameter key="decimal_point_character" value="."/> <parameter key="trim_attribute_names" value="true"/> </operator> <operator activated="true" class="replace" compatibility="9.7.000" expanded="true" height="82" name="Replace" width="90" x="179" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="[ \t]+$"/> </operator> <operator activated="true" class="replace" compatibility="9.7.000" expanded="true" height="82" name="Replace (2)" width="90" x="313" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="nominal"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="file_path"/> <parameter key="block_type" value="single_value"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="single_value"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="replace_what" value="^\s"/> </operator> <operator activated="true" class="guess_types" compatibility="9.7.000" expanded="true" height="82" name="Guess Types" width="90" x="447" y="34"> <parameter key="attribute_filter_type" value="all"/> <parameter key="attribute" value=""/> <parameter key="attributes" value=""/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> <parameter key="decimal_point_character" value="."/> </operator> <operator activated="true" class="blending:pivot" compatibility="9.7.000" expanded="true" height="82" name="Pivot" width="90" x="581" y="34"> <parameter key="group_by_attributes" value="description"/> <parameter key="column_grouping_attribute" value="Category"/> <list key="aggregation_attributes"> <parameter key="count" value="sum"/> </list> <parameter key="use_default_aggregation" value="false"/> <parameter key="default_aggregation_function" value="first"/> </operator> <connect from_op="Create ExampleSet" from_port="output" to_op="Replace" to_port="example set input"/> <connect from_op="Replace" from_port="example set output" to_op="Replace (2)" to_port="example set input"/> <connect from_op="Replace (2)" from_port="example set output" to_op="Guess Types" to_port="example set input"/> <connect from_op="Guess Types" from_port="example set output" to_op="Pivot" to_port="input"/> <connect from_op="Pivot" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="72"/> </process> </operator> </process>
1 - 3 of
31
Hey @pallav,
This can be achieved easily with pivot operator, where in you can group by description and column grouping by category at last use aggregation sum over count, that should do it.
Hey @pallav
@pallav
If you try to save the the datasets in your repo and use the dataset for further process. Here is how it looks on my end.
