In the Elbow graph with the data of SSE of the k-means, I obtain the value in the graph and they don't decrease. In your opinion, what are the possible problems?
A priori, the curve of SSE according to k (the number of cluster(s)) is increasing because RapidMiner works with negative values (RapidMiner searches to maximize the value of SSE in you are using an Optimization Loop).
If you don't obtain an increasing curve or more generally you obtain an "exotic" curve, please share your data and process in order we can reproduce and understand what's going on...
See this thread for the details :
https://community.rapidminer.com/discussion/comment/61654#Comment_61654
Hope this helps,
Regards,
Lionel
