🎉Community Raffle - Win $25
Join and Win
How to get the whole process after auto model
User: "nero786"
New Altair Community Member
Updated by Jocelyn
Hello,
I ran auto model and got the result to predict an attribute. I wanted to see the complete process after "open process", as shown on the website. But instead I am getting basic blocks inside which was the detail process. How should I use it to improve further and how to know which is the best prediction model? I am new to it and any help to accurately predict and modify the process will be appreciated.
1 - 9 of 91
    User: "lionelderkrikor"
    Hi @nero786,
    Mmhh..., just double-click on the blocks (called "subprocesses") to enter in these blocks and see what's inside these blocks...
    Hope this helps,
    Regards,
    Lionel
    User: "nero786"
    OP
    Yes I did do that and I saw bunch of processes, even I tried to attach word doc with the images of the process here on the community but don't know why it did not used it. But thanks lionelderkrikor, also all the other models shows similar processes and sub-processes. How should I improve the model from the rapid miner auto model?
    User: "nero786"
    OP
    User: "varunm1"
    Accepted Answer
    Hello @nero786
    You can also select options related to "Automatic Feature Selection" and feature generation in the auto model. You can also optimize model hyperparameters (Train Model -->optimize --> Final Optimal parameters) manually after the opening process.
    You can also custom build your model in the studio instead of the auto model.
    Accepted Answer
    Updated by lionelderkrikor
    @nero786,
    Have you got enable in Auto-Model options  :
     - Automatic Feature Selection (to find the most relevant attribute(s) for your use cases) ?
     - Automatic feature generation (to generate new relevant attributes from your initial attribute(s)) ?
    More over you can perform deeper optimization parameters by going in  :
    train model -> Optimize  ? -> click on Find Optimal Parameters (Optimize parameters operator) and click on Edit parameters settings
    EDIT : I did no see Varun's post before posting this post. I see that we had strictly the same ideas...
    Regards,
    Lionel
    User: "nero786"
    OP
    Hello Varun and Lionel,
    I did not enabled those two options. Thanks for that!!
    train model -> Optimize  ? -> click on Find Optimal Parameters (Optimize parameters operator) and click on Edit parameters settings------------ I did not see edit parameters settings.
    Smart people think the same way  ;) Lionel.
    Accepted Answer
    @nero786,
    Select the "Find Optimal Parameters" operator and you will see its parameters in the "parameters" panel.
    Then click on Edit Parameters Settings : Inside you can select the hyperparameters you want to tune and their range :
    Regards,
    Lionel
    User: "nero786"
    OP
    Thanks Lionel... you all guys are doing a great job by helping. Keep up the good work.
    User: "PSingh"
    Updated by PSingh
    Hello everyone!
    I was also trying the Auto Model in RapidMiner 9.10. Once the process completes, I also wanted to see a particular model and its process. However, when I click on the open process it gives me a generic Auto Model as @nero786 also mentioned and its not what shown in the rapidminer documentation here, https://docs.rapidminer.com/9.3/studio/auto-model/.
    Is there a way in rapidminer 9.10 to see the process of a particular model lets a random forest once the AutoModel completes running? Like the process in the attached document from Rapidminer documentation!
    @jacobcybulski any suggestions?
    Thanks in advance.
