An issue with read csv
Hello all,
so, I am trying to read a csv file, but I noticed something strange. If the first row has 4 entries, and the second row 5 entries, RM only reads the first 4 entries of the second row! It seems that the first row defines how many rows will be read. How can I fix the problem? I have thousands of rows, and I don't want to get into my database to find the row with the largest number of columns.
Regards,
Bernardo
Regards,
Bernardo
1 - 4 of
41
I assume that your first row has missing values in the attributes far right? If so, make sure the first row has enough extra commas at the end to create those attributes with missing values. Also, I think that if you have the row with headings this row will create the necessary attributes. That should fix the reading problem.
I am having the same problem. And, I like the trick. Thanks to jacobcybulski. However, though typing enough extra commas will solve the problem, it doesn't sound convenient. Best semi-automatic way is probably to move a row with the longest list of columns to the first row. But I wish there was a way to do this automatically through RM setting. Any parameter changes or or setting to do it automatically? I am trying to do Create Association Rules through FP-Growth. So the data set is a grocery shopping data.
1 - 1 of
11
