🎉Community Raffle - Win $25
Join and Win
Non-Linear analysis TABLES1 H3D File
User: "David_21305"
Altair Community Member
Updated by David_21305
Hello,
I´m running an implicit non-linear quasi-static analysis (large displacement):
As first analysis set-up I run the model without TABLES1 (MATS1) properties. My model ran successfully and created all binary files (H3D, res).
When I add tables1 to my analysis, status-window states my model has converged but it did not create h3d, res files, just some scratch files "*.rs".
I just added the tables1 and modified mats1 properties. Why can´t I see h3d files? I have read scratch files are generated when there is a problem with the analysis.
Thanks!
1 - 2 of 21
    User: "Rogerio Nakano_21179"
    New Altair Community Member
    Updated by Rogerio Nakano_21179
    Hi
    you can check the *.out file for any warning or error message.
    Also, if you are using the option with TABLES1, check that the curve is always increasing on tension value.
    I hope this is helpful.
    Regards
    User: "David_21305"
    OP
    Hello,
    There are some **INFORMATION messages in the .OUT file:
    #1579
     for material id = 1 referenced from property id = 1.
     MATS1 referred to from MID3 will be ignored - plasticity is
     supported for membrane and bending deformation, but not for transverse shear.
    #4736
    #4739
    I´m using the MAT1..MATS1..TABLES1 for quad elements (PSHELL).
    I have warning messages but just related mesh quality, I have the same parameters and slide contact for the analysis without TABLES1 and it runs successfully (creating binary files).
    TABLES1 is always increasing on tension value.
