🎉Community Raffle - Win $25
Join and Win
Find nodes assigned to a system
User: "Beta"
New Altair Community Member
Updated by Beta
hi,
I am looking for a solution to find out the IDs of nodes assigned to a system which I already know the ID.
Is there anybody having any ideas how to do that ??
1 - 12 of 121
    User: "tinh"
    Updated by tinh
    *createmark nodes 1 'by system' ?
    User: "Beta"
    OP
    Updated by Beta
    Hi Tinh.
    Nodes are not selectable with 'by system'
    User: "tinh"
    Updated by tinh
    *createmark nodes 1 'equal to value' inputsystemid ?
    User: "Beta"
    OP
    Updated by Beta
    hi Tinh,
    No change, node is not selected.
    User: "tinh"
    Updated by tinh
    Is that an input system or output system?
    User: "vipin_22401"
    Updated by vipin_22401
    hi,
    Hi @Toan Nguyen
    this could work for you.
    set sysId 1
    hm_getcrossreferencedentities systems $sysId 7 1 0 0 -byid
    hm_getmark nodes 1
    User: "Beta"
    OP
    Updated by Beta
    @tinh
    It is an output system which is used to set displacement of nodes on that system.
    @vipin
    It doesn't work with the following message:
    hm_getcrossreferencedentities: unable to find the entity by id ' '1''.
    Please note that the system with ID 1 existed in the model I used for checking
    User: "vipin_22401"
    Hi @Toan Nguyen
    it is working for me. is it because of the hypermesh version?
    I am using 2017 version.
    User: "tinh"
    Updated by tinh
    @tinh
    @vipin
    So you found answer base on my *createmark command, didn't you? ;)/emoticons/default_wink.png' srcset='/emoticons/wink@2x.png 2x' title=';)' width='20' />
    I searched it by inputsystem
    User: "Beta"
    OP
    Updated by Beta
    hi @tinh @vipin
    It works now, I forgot to set up a User Profiles.
    Thank you very much for the help from all of you!
    User: "vipin_22401"
    Great!
    I too searched something similar @tinh:D/emoticons/default_biggrin.png' srcset='/emoticons/biggrin@2x.png 2x' title=':D' width='20' />
    User: "Beta"
    OP
    Updated by Beta
    Just to provide some additional information:
    I used those command on HW14. Initially, It returned an error 'invalid entity type', so I changed the entity types from 'systems' to 'systs' then It worked.
