Hi,
Need clarification regarding FRF Analysis in Optistruct. What is the difference by applying excitation in two different cases? For example we need to apply 1g excitation. How to apply in below cases?
Case 1 - Using RBE2/RBE3
Case 2 - Separate
Regards,
Arul
I guess case 1 is the right method (spcd is applied at the independent node) instead of exciting at all points.
