how to draw multi series in scatter 3d
User: "will_w7tl9"
New Altair Community Member
Updated by Jocelyn
plz take a look this demo -> jsfiddle.net/p5qxqshd
i've generated two csv file like this for test by using scatter 3d,
x,y,z
0,3.339803706241991,3
0.1,3.3374696427494337,3
0.2,3.1172990941528935,3
0.3,3.489850784196743,3
but i did not success ...
So i updated two attachments for test ,if anybody would help me :) Thank you very much ~
1 - 6 of 61
    User: "hbajpai"
    Hey @will_w7tl9,
    I tried to plot a 3D scatter plot with your first csv, it looks like below figure. You can plot different series by setting series name as color in the plot.
    User: "will_w7tl9"
    OP
    Hi @hbajpai ,
    Thank you so much for reply me ~
    I am confused about how to set the z axis, especially when multiple series are displayed at the same time just like the jsfiddle.net/p5qxqshd demo.
    If i provide a mix csv file,would you please let me know how to display two series with diffrent z-axis (z1,z2) using scatter 3d ?
    Thanks !
    User: "hbajpai"
    Accepted Answer
    Updated by hbajpai
    Hey @will_w7tl9 ,
    You will need pre-processing of data tad bit. The plot will then look like below.
    I have attached the XML code which you can use to replicate the process. If you are not aware of how use XML code in rapid miner check out this post : https://community.rapidminer.com/discussion/comment/32610#Comment_32610
    <?xml version="1.0" encoding="UTF-8"?><process version="9.6.000">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.6.000" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="read_csv" compatibility="9.6.000" expanded="true" height="68" name="Read CSV" width="90" x="179" y="34">
            <parameter key="csv_file" value="C:UsersharshDownloadsline-all.csv"/>
            <parameter key="column_separators" value=","/>
            <parameter key="trim_lines" value="false"/>
            <parameter key="use_quotes" value="true"/>
            <parameter key="quotes_character" value="&quot;"/>
            <parameter key="escape_character" value=""/>
            <parameter key="skip_comments" value="true"/>
            <parameter key="comment_characters" value="#"/>
            <parameter key="starting_row" value="1"/>
            <parameter key="parse_numbers" value="true"/>
            <parameter key="decimal_character" value="."/>
            <parameter key="grouped_digits" value="false"/>
            <parameter key="grouping_character" value=","/>
            <parameter key="infinity_representation" value=""/>
            <parameter key="date_format" value=""/>
            <parameter key="first_row_as_names" value="true"/>
            <list key="annotations"/>
            <parameter key="time_zone" value="SYSTEM"/>
            <parameter key="locale" value="English (United States)"/>
            <parameter key="encoding" value="windows-1252"/>
            <parameter key="read_all_values_as_polynominal" value="false"/>
            <list key="data_set_meta_data_information">
              <parameter key="0" value="x1.true.real.attribute"/>
              <parameter key="1" value="y1.true.real.attribute"/>
              <parameter key="2" value="z1.true.integer.attribute"/>
              <parameter key="3" value="x2.true.real.attribute"/>
              <parameter key="4" value="y2.true.real.attribute"/>
              <parameter key="5" value="z2.true.integer.attribute"/>
            </list>
            <parameter key="read_not_matching_values_as_missings" value="false"/>
            <parameter key="datamanagement" value="double_array"/>
            <parameter key="data_management" value="auto"/>
          </operator>
          <operator activated="true" class="multiply" compatibility="9.6.000" expanded="true" height="103" name="Multiply" width="90" x="313" y="34"/>
          <operator activated="true" class="select_attributes" compatibility="9.6.000" expanded="true" height="82" name="Select Attributes (2)" width="90" x="447" y="136">
            <parameter key="attribute_filter_type" value="subset"/>
            <parameter key="attribute" value=""/>
            <parameter key="attributes" value="x2|y2|z2"/>
            <parameter key="use_except_expression" value="false"/>
            <parameter key="value_type" value="attribute_value"/>
            <parameter key="use_value_type_exception" value="false"/>
            <parameter key="except_value_type" value="time"/>
            <parameter key="block_type" value="attribute_block"/>
            <parameter key="use_block_type_exception" value="false"/>
            <parameter key="except_block_type" value="value_matrix_row_start"/>
            <parameter key="invert_selection" value="false"/>
            <parameter key="include_special_attributes" value="false"/>
          </operator>
          <operator activated="true" class="rename" compatibility="9.6.000" expanded="true" height="82" name="Rename (2)" width="90" x="581" y="136">
            <parameter key="old_name" value="x2"/>
            <parameter key="new_name" value="x"/>
            <list key="rename_additional_attributes">
              <parameter key="y2" value="y"/>
              <parameter key="z2" value="z"/>
            </list>
          </operator>
          <operator activated="true" class="generate_attributes" compatibility="9.6.000" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="715" y="136">
            <list key="function_descriptions">
              <parameter key="Series" value="&quot;Series2&quot;"/>
            </list>
            <parameter key="keep_all" value="true"/>
          </operator>
          <operator activated="true" class="select_attributes" compatibility="9.6.000" expanded="true" height="82" name="Select Attributes" width="90" x="447" y="34">
            <parameter key="attributes" value="x1|y1|z1"/>
          </operator>
          <operator activated="true" class="rename" compatibility="9.6.000" expanded="true" height="82" name="Rename" width="90" x="581" y="34">
            <parameter key="old_name" value="x1"/>
              <parameter key="y1" value="y"/>
              <parameter key="z1" value="z"/>
            </list>
          </operator>
          <operator activated="true" class="generate_attributes" compatibility="9.6.000" expanded="true" height="82" name="Generate Attributes" width="90" x="715" y="34">
              <parameter key="Series" value="&quot;Series1&quot;"/>
            </list>
          </operator>
          <operator activated="true" class="append" compatibility="9.6.000" expanded="true" height="103" name="Append" width="90" x="916" y="34">
            <parameter key="merge_type" value="all"/>
          </operator>
          <connect from_op="Read CSV" from_port="output" to_op="Multiply" to_port="input"/>
          <connect from_op="Multiply" from_port="output 1" to_op="Select Attributes" to_port="example set input"/>
          <connect from_op="Multiply" from_port="output 2" to_op="Select Attributes (2)" to_port="example set input"/>
          <connect from_op="Select Attributes (2)" from_port="example set output" to_op="Rename (2)" to_port="example set input"/>
          <connect from_op="Rename (2)" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/>
          <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Append" to_port="example set 2"/>
          <connect from_op="Select Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/>
          <connect from_op="Rename" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
          <connect from_op="Generate Attributes" from_port="example set output" to_op="Append" to_port="example set 1"/>
          <connect from_op="Append" from_port="merged set" to_port="result 1"/>
        </process>
      </operator>
    </process>
    User: "will_w7tl9"
    OP
    Hi @hbajpai
    Thx ! Now i've got the plot look like this
    But i have another issue, how do i set the series style like this (marker enabled -> false):
    In other words, how do I set the style so that the line style becomes like this
    User: "hbajpai"
    Hey @will_w7tl9,
    I do not think Rapid Miner has a 3D line plot yet. So, you can only 3D plot scatter plots.
    User: "will_w7tl9"
    OP
    finally i got it ...(by edit the source code)
