🎉Community Raffle - Win $25
Join and Win
How to generate sequence using generate id in given format
User: "sgnarkhede2016"
New Altair Community Member
Updated by Jocelyn
Hello,
I want to Generate profile Id in below format.
CBP00001
CBP00002
CBP00003
First time my ProfileId CBP00001 but next iteration comes it should be incremented by One "CBP00002"
These four '0000' are not constant if ten Id comes then Id Should be  "CBP00010"
for reference see my process
<?xml version="1.0" encoding="UTF-8"?><process version="9.5.001">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.5.001" expanded="true" name="Process">
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <process expanded="true">
      <operator activated="false" class="read_csv" compatibility="9.5.001" expanded="true" height="68" name="Read CSV" width="90" x="849" y="340">
        <parameter key="csv_file" value="C:\Users\snarkhede\Desktop\test.csv"/>
        <parameter key="column_separators" value=";"/>
        <parameter key="trim_lines" value="false"/>
        <parameter key="use_quotes" value="true"/>
        <parameter key="quotes_character" value="&quot;"/>
        <parameter key="escape_character" value="\"/>
        <parameter key="skip_comments" value="true"/>
        <parameter key="comment_characters" value="#"/>
        <parameter key="starting_row" value="1"/>
        <parameter key="parse_numbers" value="true"/>
        <parameter key="decimal_character" value="."/>
        <parameter key="grouped_digits" value="false"/>
        <parameter key="grouping_character" value=","/>
        <parameter key="infinity_representation" value=""/>
        <parameter key="date_format" value="M/d/yy h:mm a"/>
        <parameter key="first_row_as_names" value="true"/>
        <list key="annotations"/>
        <parameter key="time_zone" value="SYSTEM"/>
        <parameter key="locale" value="English (United States)"/>
        <parameter key="encoding" value="windows-1252"/>
        <parameter key="read_all_values_as_polynominal" value="false"/>
        <list key="data_set_meta_data_information">
          <parameter key="0" value="Institution Id.true.polynominal.attribute"/>
          <parameter key="1" value="Customer Id.true.polynominal.attribute"/>
          <parameter key="2" value="AVG_TRANSACTED_AMOUNT.true.polynominal.attribute"/>
          <parameter key="3" value="MIN_TRANSACTED_AMOUNT.true.polynominal.attribute"/>
          <parameter key="4" value="MAX_TRANSACTED_AMOUNT.true.polynominal.attribute"/>
          <parameter key="5" value="STD_TRANSACTED_AMOUNT.true.polynominal.attribute"/>
          <parameter key="6" value="MEDIAN_TRANSACTED_AMOUNT.true.polynominal.attribute"/>
          <parameter key="7" value="TOTAL_AMOUNT.true.polynominal.attribute"/>
          <parameter key="8" value="Account Number.true.polynominal.attribute"/>
          <parameter key="9" value="Customer.true.polynominal.attribute"/>
          <parameter key="10" value="AVG_NO_OF_TRANSACTIONS.true.polynominal.attribute"/>
          <parameter key="11" value="MIN_NO_OF_TRANSACTIONS.true.polynominal.attribute"/>
          <parameter key="12" value="MAX_NO_OF_TRANSACTIONS.true.polynominal.attribute"/>
          <parameter key="13" value="STD_NO_OF_TRANSACTIONS.true.polynominal.attribute"/>
          <parameter key="14" value="MEDIAN_NO_OF_TRANSACTIONS.true.polynominal.attribute"/>
          <parameter key="15" value="NO_OF_TRANSACTIONS.true.polynominal.attribute"/>
          <parameter key="16" value="AVG_TOTAL_AMOUNT_PER_BIN.true.polynominal.attribute"/>
          <parameter key="17" value="MIN_TOTAL_AMOUNT_PER_BIN.true.polynominal.attribute"/>
          <parameter key="18" value="MAX_TOTAL_AMOUNT_PER_BIN.true.polynominal.attribute"/>
          <parameter key="19" value="STD_TOTAL_AMOUNT_PER_BIN.true.polynominal.attribute"/>
          <parameter key="20" value="LAST_NORMAL_BUILD_DATE.true.date_time.attribute"/>
        </list>
        <parameter key="read_not_matching_values_as_missings" value="true"/>
        <parameter key="datamanagement" value="double_array"/>
        <parameter key="data_management" value="auto"/>
      </operator>
      <operator activated="false" class="utility:create_exampleset" compatibility="9.5.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="493">
        <parameter key="generator_type" value="numeric series"/>
        <parameter key="number_of_examples" value="1000"/>
        <parameter key="use_stepsize" value="true"/>
        <list key="function_descriptions"/>
        <parameter key="add_id_attribute" value="false"/>
        <list key="numeric_series_configuration">
          <parameter key="ProfileID" value="linear.1\.0.1\.0"/>
        </list>
        <list key="date_series_configuration"/>
        <list key="date_series_configuration (interval)"/>
        <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
        <parameter key="column_separator" value=","/>
        <parameter key="parse_all_as_nominal" value="false"/>
        <parameter key="decimal_point_character" value="."/>
        <parameter key="trim_attribute_names" value="true"/>
      </operator>
      <operator activated="false" class="generate_attributes" compatibility="9.5.001" expanded="true" height="82" name="Generate Attributes (5)" width="90" x="246" y="493">
        <list key="function_descriptions">
          <parameter key="NEW_ID" value="concat(&quot;CBP&quot;,suffix(concat(&quot;0000&quot;,str(ProfileID)),5))"/>
        </list>
        <parameter key="keep_all" value="true"/>
      </operator>
      <operator activated="true" class="generate_data" compatibility="9.5.001" expanded="true" height="68" name="Generate Data" width="90" x="179" y="238">
        <parameter key="target_function" value="random"/>
        <parameter key="number_examples" value="100"/>
        <parameter key="number_of_attributes" value="5"/>
        <parameter key="attributes_lower_bound" value="-10.0"/>
        <parameter key="attributes_upper_bound" value="10.0"/>
        <parameter key="gaussian_standard_deviation" value="10.0"/>
        <parameter key="largest_radius" value="10.0"/>
        <parameter key="use_local_random_seed" value="false"/>
        <parameter key="local_random_seed" value="1992"/>
      </operator>
      <operator activated="true" class="set_macro" compatibility="9.5.001" expanded="true" height="82" name="Set Macro (3)" width="90" x="313" y="238">
        <parameter key="macro" value="myMacro"/>
        <parameter key="value" value="5.0"/>
      </operator>
      <operator activated="true" class="generate_attributes" compatibility="9.5.001" expanded="true" height="82" name="Generate Attributes (6)" width="90" x="447" y="238">
          <parameter key="id1" value="%{myMacro}"/>
        </list>
      </operator>
      <operator activated="true" class="replace" compatibility="6.0.003" expanded="true" height="82" name="Replace (6)" width="90" x="581" y="238">
        <parameter key="attribute_filter_type" value="all"/>
        <parameter key="attribute" value=""/>
        <parameter key="attributes" value=""/>
        <parameter key="use_except_expression" value="false"/>
        <parameter key="value_type" value="nominal"/>
        <parameter key="use_value_type_exception" value="false"/>
        <parameter key="except_value_type" value="file_path"/>
        <parameter key="block_type" value="single_value"/>
        <parameter key="use_block_type_exception" value="false"/>
        <parameter key="except_block_type" value="single_value"/>
        <parameter key="invert_selection" value="false"/>
        <parameter key="include_special_attributes" value="false"/>
        <parameter key="replace_what" value=".0"/>
      </operator>
      <operator activated="true" class="parse_numbers" compatibility="6.0.003" expanded="true" height="82" name="Parse Numbers" width="90" x="715" y="238">
        <parameter key="attribute_filter_type" value="single"/>
        <parameter key="attribute" value="id1"/>
        <parameter key="unparsable_value_handling" value="fail"/>
      </operator>
      <operator activated="true" class="extract_macro" compatibility="9.5.001" expanded="true" height="68" name="Extract Macro (7)" width="90" x="849" y="238">
        <parameter key="macro" value="profile_id"/>
        <parameter key="macro_type" value="data_value"/>
        <parameter key="statistics" value="average"/>
        <parameter key="attribute_name" value="id1"/>
        <parameter key="example_index" value="1"/>
        <list key="additional_macros"/>
      </operator>
      <operator activated="true" class="generate_id" compatibility="9.5.001" expanded="true" height="82" name="Generate ID (9)" width="90" x="983" y="238">
        <parameter key="create_nominal_ids" value="false"/>
        <parameter key="offset" value="%{profile_id}"/>
      </operator>
      <operator activated="true" class="generate_attributes" compatibility="9.5.001" expanded="true" height="82" name="Generate Attributes (11)" width="90" x="1117" y="238">
          <parameter key="id" value="concat(&quot;CBP&quot;,suffix(concat(&quot;0000&quot;,str(id)),5))"/>
        </list>
      </operator>
      <connect from_op="Create ExampleSet" from_port="output" to_op="Generate Attributes (5)" to_port="example set input"/>
      <connect from_op="Generate Data" from_port="output" to_op="Set Macro (3)" to_port="through 1"/>
      <connect from_op="Set Macro (3)" from_port="through 1" to_op="Generate Attributes (6)" to_port="example set input"/>
      <connect from_op="Generate Attributes (6)" from_port="example set output" to_op="Replace (6)" to_port="example set input"/>
      <connect from_op="Replace (6)" from_port="example set output" to_op="Parse Numbers" to_port="example set input"/>
      <connect from_op="Parse Numbers" from_port="example set output" to_op="Extract Macro (7)" to_port="example set"/>
      <connect from_op="Extract Macro (7)" from_port="example set" to_op="Generate ID (9)" to_port="example set input"/>
      <connect from_op="Generate ID (9)" from_port="example set output" to_op="Generate Attributes (11)" to_port="example set input"/>
      <connect from_op="Generate Attributes (11)" from_port="example set output" to_port="result 1"/>
    </process>
  </operator>
</process>
1 - 1 of 11
