Cannot install RapidMiner Server
When trying to install RapidMiner from the installation files (bin directory) the command window opens for a second and disappears. File path: "C:\Users\ferga.LAPTOP-AER3Q2L6\Downloads\rapidminer-server-installer-9.6.0\rapidminer-server-installer-9.6.0\bin\rapidminer-server-installer.bat"
1 - 3 of
31
Hi! I think you stopped the window from disappearing by doing a right-click which holds the entire Windows process. As mentioned in this thread (https://community.rapidminer.com/discussion/56528/i-cannot-seem-to-download-rapidminer-server) I think it would be beneficial if we have the terminal output.
I am assuming that you might not have all the required system requirements. Also, make sure you are running RapidMiner Server Installer as Admin. Please refer to the step by step instructions and see if you are missing any step.
Let me know if that works for you.
