Problem with downloading Rapidminer Server
hey, when I tried to download rapidminer, i downloaded the packages and had the rapid-server installer ran by java. But besides showing the following codes as the picture shows, nothing else happened. I have downloaded a PostgreSQL and pgAdmin. Can you help me identify the problem?
1 - 6 of
61
sgenzer
hi @ShineT - just to make sure...you are following these steps, right? https://docs.rapidminer.com/latest/server/install/
Hi @ShineT,
Looks like java error, what's the version of the Java you have it installed on this machine?
Please review the system requirements here.
https://docs.rapidminer.com/latest/server/install/system-requirements.html
Cheers,
Pavithra
Cheers,
Pavithra
Hi @Pavithra_Rao,
I have downloaded java 8 from Oracle: macOS x64 Installer. I tried to run the installer again but it still didn't work and showed the same codes I pasted on my original post.
Hi @Pavithra_Rao,
So I have changed my macOS setting to use zsh. And here is the updated code that showed up after I clicked the installer:
I have also tried to re-download the java and it turned out to be the same result.
Thanks,
Shine
Thanks,
Shine
