🎉Community Raffle - Win $25
Join and Win
how to add quotes each word in string(these are my attributes name)
User: "sgnarkhede2016"
New Altair Community Member
Updated by Jocelyn
e.g.
query=Sachin,Amit,Clara,Josef'
it should be converted into
query='Sachin','Amit','Clara','Josef'
1 - 3 of 31
    User: "[Deleted User]"
    Updated by [Deleted User]
    @sgnarkhede2016
    Hello
    I think you can use Replace operator  :). Read the document please and take a look at other link ;)
    https://docs.rapidminer.com/latest/studio/operators/blending/values/replace.html
    https://community.rapidminer.com/discussion/comment/63890#Comment_63890
    I hope this helps
    mbs
    OP
    but in replace operator i need to pass "regex" it not working for me
    e.g
    Sachin N
    Jonn Clara
    I have passed "replace what"  \^(\w+ \w+)
                             "replace by"   \("\w+ \w+")
    I want above string as "Sachin N" and "John Clara"
    User: "kayman"
    Accepted Answer
    \^ escapes your special symbol, so instead of starting at the beginning of your attribute (what would happen with ^) your expression is now looking for the character ^ instead.
    You will also only find matches that are word + word, so if your attribute is existing of a single word it will fail also.
    What would probably work better is something like this :
    ^(.*)$ which means just select my whole attribute value from beginning to end, and replace with "$1" , so quot + stored result + quote
