🎉Community Raffle - Win $25
Join and Win
One Rule (OneR)
User: "sdr42016"
New Altair Community Member
Updated by Jocelyn
Hi everyone,
is there any way to implement One Rule (OneR) algorithm in Rapid Miner? Maybe it is implemented with another name, but I can't find it in the 'Operators' section.
Best regards
1 - 2 of 21
    User: "varunm1"
    Updated by varunm1
    Hello @sdr42016
    I am not sure if Rapidminer has native operator for this. But, if you install Weka extension from rapidminer marketplace, then there is W-OneR operator in that.
    To install weka extension, you need to go to Extension --> Marketplace and then search for Weka.
    Hope this helps
    User: "BalazsBaranyRM"
    Hi,
    RapidMiner calls this Decision Stump. It's among the tree based methods.
    If you want the model to be a rule, not a (minimal) tree, check out Tree to Rules.
    You can also limit the normal decision tree to maximal depth = 2, which will give you a one-rule decision, but with the positive properties of Decision Tree. (parallel processing, large number of settings, ...)
    There is also Single Rule Induction, but it's not very flexible.
    Regards,
    Balázs
