🎉Community Raffle - Win $25
Join and Win
which version of rapidminer is 64bit?
User: "amir9121"
New Altair Community Member
Updated by Jocelyn
hi
This is an awkward question because I'm a beginner user, i want to know does 5.3 version of rapidminer has 64bit version?
1 - 5 of 51
    Hi,
    RM 5.3 is not supported anymore. We highly recommend to use 9.X. They are all 64bit.
    Best,
    Martin
    User: "amir9121"
    OP
    thanks for your answering...yes i know 5.3 is old version...jus i want to know does this version has 64bit or not? ...in fact i am testing project and learning RM and know this is so expensive to buy 9.x version...by the way thank you very much.
    User: "BalazsBaranyRM"
    Hi @amir9121
    RapidMiner is written in Java. 64 or 32 bit is a property of the Java runtime you're using. You can use any RapidMiner version with either a 32 or a 64 bit Java runtime.
    The "64 bit" refers to the included Java runtime. Just install a 64 bit Java and execute your old unsupported RapidMiner with it if you must. But you will really miss many great features.
    Regards,
    Balázs
    User: "amir9121"
    OP
    thank for your guide but i do as you say install is beside jre 64bit but for installing R extension i forced to install jre 32 and R 32 bit version, why was that? also i cant use all of my ram capacity yet...
    User: "David_A"
    Updated by David_A
    Hi,
    Do you by chance mean the old R extension (https:// marketplace.rapidminer.com/UpdateServer/faces/product_details.xhtml?productId=rmx_r)? That one is deprecated and should not be used.
    The current version (https://marketplace.rapidminer.com/UpdateServer/faces/product_details.xhtml?productId=rmx_r_scripting ) is completely independent of your JRE and will work fine with 64bit.
    Best,
    David
