🎉Community Raffle - Win $25
Join and Win
Is there a way to measure the performance of a Word2Vec model?
User: "Christos_Karapapas"
New Altair Community Member
Updated by Jocelyn
I am using the word2vec extension to train a model for polynomial text classification.
None of the standard Performance operators seem to "stack" with the word2vec model (RMWord2VecModel).
Is there any way that I could measure the performance of the model on the training dataset?
1 - 3 of 31
    good question! Usually Word2Vec is either evaluated empircally (close words should be "synonyms", close in meaning) or by using down stream tasks like Entity Recognition.
    Cheers,
    Martin
    OP
    So, if I understand it correctly it's just another way of finding synonyms just like when grouping words by their root (lemmas)?
    And if so why it exports a model? To be used in later processes with different datasets and still be able to find the lemma of a word?
    User: "Telcontar120"
    Yes, it is more of a processing model than a predictive model.  Most unsupervised ML approaches don't have th same kind of performance measurement as you are used to from standard predictive models.
