ANN for my data
Hi all,
i need help to analyze my data set for my thesis but could not proceed per my limited knowledge about rapidminer. I have accidents taken place in construction and some attributes. I want to use root causes (15 type of root cause-15 neurons) and immediate causes (19 types of causes-19 neurons) as layers in neural networks and try to predict outcomes as event exposure types (6 different types). For example (from picture) first accident took place in 27.06.2015 @ 16:15 and resulted in Falling from height. IC3, IC10 and IC16 contributed as immediate causes. RC4 and RC15 are root causes that led to accidents.In other words for first accident activation of neurons (3-10-16 in first layer) activates neurons in second layer (neurons 4 and 15) and one outcome occurs. I have many of accidents like this. See pic for illustration. I need urgent help, any help is appreciated.
1 - 5 of
51
sgenzer
Thank you for the suggestion, i went through it but still need more help
Hi @LuckyLuke,
I'm not specialist of neural network(s) but at first sight I don't know how to handle ICF and RCF directly like that.
From my opinion , you have first to split :
- your "meta attribute" ICF into 5 attributes (called for example ICF-1, ...,ICF-5) because according to your screenshot
you can have up to 5 possible ICF for a given accident
- your "meta attribute" RCF into 4 attributes (called for example RCF-1, ...,RCF-4) because according to your screenshot
you can have up to 4 possible RCF for a given accident.
More over I'm not sure to understand , what is your label ? (the attribute you want to predict).
The best is, if possible, to share your dataset. I will try to play with your data / build a model.
Regards,
Lionel
Regards,
Lionel
Hi lionelderkrikor, i want to predict event exposure type (F, T, C etc.). may i have your email to send you my data set ?
Scott
