🎉Community Raffle - Win $25
Join and Win
Bagging optmization reduced performance
User: "ravtal"
New Altair Community Member
Updated by Jocelyn
Hi,
I am running an attached dataset to measure the performance of the model. Decision tree gave me a good accuracy value, however, when I used a bagging operator to increase the performance of the model, the output reduced the performance accuracy.
Could anyone help me with what changes I need to make in the model so that accuracy is optimized?
Note: dataset has no attribute tables, uncheck "first row as names" and column operator value to "," while importing the dataset.
Regards,
RT
1 - 4 of 41
    Hi @ravtal,
    this sounds like you overtrained your decision tree. Did you check for it?
    Best,
    Martin
    User: "ravtal"
    OP
    You mean I should reduce the depth?
    User: "varunm1"
    Hello @ravtal
    As @mschmitz said, it might be due to overfitting. DId you try hyperparameter optimization using "optimize parameter grid operator"? You can search for the best hyperparameters for your algorithm and reduce overfitting.
    User: "ravtal"
    OP
    @varunm1 Ok, but do you think model design is good?
