🎉Community Raffle - Win $25
Join and Win
RM Studio 9.5.001 - New Connection SQL Server - tables not showing
User: "User110840"
New Altair Community Member
Updated by Jocelyn
I just got a new win10 rebuild and installed RM 9.5.001 -- I went to add my new connection (vs the old legacy method) to a 2017 SQL Server.  I connected with following URL
(Note - I replaced my real server and db name in string)
jdbc:sqlserver://SQLSERVER:1433;databaseName=MYDBNAME;integratedSecurity=true
I have a Local Repository-->Connection-->MYSQLServer_Connection - I can pass the TEST CONNECTION and I am able to +Import a data table.
In my prior version of RM Studio, I was able to use down arrow on the DBName to see all my tables and then access them via retrieve.  When I pull in the retrieve operator now, I just see the MYSQLServer_Connection and no way to get to the data.
I assume I am not using the right driver or something -- PLEASE HELP.
thanks...litia
1 - 3 of 31
    User: "Marco_Boeck"
    Accepted Answer
    Updated by Marco_Boeck
    Hi,
    You can still do it, e.g. like this:
    Make sure you select "table name". You may need to press the refresh button next to the dropdown once.
    Regards,
    Marco
    User: "User110840"
    OP
    thank you -- I did stumble into this method but was looking for the table references in the repository directly -- thank you and I will just make this adjustment in my work...
    User: "Marco_Boeck"
    Hi,
    The DB repository was quite frankly very broken in many cases, and is therefore not supporting the new connections and will be dropped eventually.
    Regards,
    Marco
