Generate Attribute depending on 2 values in previous rows
Hi there,
I already searched the forum but did not find anything very helpful.
Let´s say I have some easy sales-data in an example-set like this:
Week | Product | UnitPrice | Unit_Sales
01_19| Beer_A | 0.99 | 10
02_19| Beer_A | 0.85 | 20
I would like to generate a new Attribute which:
- either gives the price of a product of the last week
- or already calulates the price-difference from the previous week to the actual row/week
Is that even possible with the operator Generate Attribute?
Best regards and have a nice day
1 - 4 of
41
MartinLiebig
Hi,
you most likely want to use first the Lag operator and combine this with Generate Attributes.
Cheers,
Martin
Hi @MPB_
please have a look at the attached process. That should explain it.
BR,
Martin
<?xml version="1.0" encoding="UTF-8"?><process version="9.4.001"><br> <context><br> <input/><br> <output/><br> <macros/><br> </context><br> <operator activated="true" class="process" compatibility="9.4.001" expanded="true" name="Process"><br> <parameter key="logverbosity" value="init"/><br> <parameter key="random_seed" value="2001"/><br> <parameter key="send_mail" value="never"/><br> <parameter key="notification_email" value=""/><br> <parameter key="process_duration_for_mail" value="30"/><br> <parameter key="encoding" value="SYSTEM"/><br> <process expanded="true"><br> <operator activated="true" class="utility:create_exampleset" compatibility="9.4.001" expanded="true" height="68" name="Create ExampleSet" width="90" x="179" y="85"><br> <parameter key="generator_type" value="comma separated text"/><br> <parameter key="number_of_examples" value="100"/><br> <parameter key="use_stepsize" value="false"/><br> <list key="function_descriptions"/><br> <parameter key="add_id_attribute" value="false"/><br> <list key="numeric_series_configuration"/><br> <list key="date_series_configuration"/><br> <list key="date_series_configuration (interval)"/><br> <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/><br> <parameter key="time_zone" value="SYSTEM"/><br> <parameter key="input_csv_text" value="Week | Product | UnitPrice | Unit_Sales 01_19| Beer_A | 0.99 | 10 02_19| Beer_A | 0.85 | 20"/><br> <parameter key="column_separator" value="\|"/><br> <parameter key="parse_all_as_nominal" value="false"/><br> <parameter key="decimal_point_character" value="."/><br> <parameter key="trim_attribute_names" value="true"/><br> </operator><br> <operator activated="true" class="time_series:lag_series" compatibility="9.4.001" expanded="true" height="82" name="Lag" width="90" x="380" y="85"><br> <list key="attributes"><br> <parameter key="UnitPrice" value="1"/><br> </list><br> <parameter key="overwrite_attributes" value="false"/><br> <parameter key="extend_exampleset" value="false"/><br> </operator><br> <operator activated="true" class="generate_attributes" compatibility="9.4.001" expanded="true" height="82" name="Generate Attributes" width="90" x="581" y="85"><br> <list key="function_descriptions"><br> <parameter key="DeltaPrice" value="[UnitPrice-1]-UnitPrice"/><br> </list><br> <parameter key="keep_all" value="true"/><br> </operator><br> <connect from_op="Create ExampleSet" from_port="output" to_op="Lag" to_port="example set input"/><br> <connect from_op="Lag" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/><br> <connect from_op="Generate Attributes" from_port="example set output" to_port="result 1"/><br> <portSpacing port="source_input 1" spacing="0"/><br> <portSpacing port="sink_result 1" spacing="0"/><br> <portSpacing port="sink_result 2" spacing="0"/><br> </process><br> </operator><br></process><br><br>
1 - 1 of
11
Hi @MPB_
BR,
Martin
