The advantage of using the Server remote execution is that all processes are already setup to store the results again in the repo. If you would do the same with AM running in Studio and press Save Results at the end, the outcome is almost the same but you would need to change the processes by defining the correct output locations in the context for each process for all 20+ results. Possible, but the Server approach is just simpler…
Hope this helps,Ingo
