Xpath - Getting text from div
Hey folks,
I've tested my xpath in google docs and it's working fine however I can't get it to work in Rapidminer. In the Extract Information operator if I use the query "//h:div[2]/h:div/h:ul/h:li[1]/h:div" I get the result below:
<div xmlns="http://www.w3.org/1999/xhtml" class="stats-value">
<svg class="icon">
<use xmlns:xlink="urn:x-prefix:xlink" xlink:href="#trophy" />
</svg>
Text that I want
</div>
However I just want the text "Text that I want" not the surrounding html. So I try "//h:div[2]/h:div/h:ul/h:li[1]/h:div/text()". This doesn't give me an error but it's not returning anything, no text at all.
Any help is much appreciated.
Neil.
Neil.
1 - 8 of
81
Please find code below and excel file with links. Thanks for your help
<?xml version="1.0" encoding="UTF-8"?><process version="9.5.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.5.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="9.5.000" expanded="true" height="68" name="Read Excel (2)" width="90" x="45" y="136"> <parameter key="excel_file" value="D:\OneDrive\snookersmall.xlsx"/> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"/> <parameter key="read_not_matching_values_as_missings" value="true"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="web:retrieve_webpages" compatibility="9.0.000" expanded="true" height="68" name="Get Pages (2)" width="90" x="313" y="136"> <parameter key="link_attribute" value="LINKS"/> <parameter key="random_user_agent" value="false"/> <parameter key="user_agent" value="googlebot"/> <parameter key="connection_timeout" value="10000"/> <parameter key="read_timeout" value="10000"/> <parameter key="follow_redirects" value="true"/> <parameter key="accept_cookies" value="none"/> <parameter key="cookie_scope" value="global"/> <parameter key="request_method" value="GET"/> <parameter key="delay" value="none"/> <parameter key="delay_amount" value="1000"/> <parameter key="min_delay_amount" value="0"/> <parameter key="max_delay_amount" value="1000"/> </operator> <operator activated="true" class="text:process_document_from_data" compatibility="8.2.000" expanded="true" height="82" name="Process Documents from Data (2)" width="90" x="581" y="136"> <parameter key="create_word_vector" value="true"/> <parameter key="vector_creation" value="TF-IDF"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <parameter key="select_attributes_and_weights" value="false"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:extract_information" compatibility="8.2.000" expanded="true" height="68" name="Extract Information (2)" width="90" x="246" y="34"> <parameter key="query_type" value="XPath"/> <list key="string_machting_queries"/> <parameter key="attribute_type" value="Nominal"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"> <parameter key="Snookname" value="//h:div[1]/h:h1/text()"/> <parameter key="Titleswon" value="//h:div[2]/h:div/h:ul/h:li[1]/h:div/text()"/> </list> <list key="namespaces"/> <parameter key="ignore_CDATA" value="true"/> <parameter key="assume_html" value="true"/> <list key="index_queries"/> <list key="jsonpath_queries"/> </operator> <operator activated="true" class="web:extract_html_text_content" compatibility="9.0.000" expanded="true" height="68" name="Extract Content (2)" width="90" x="514" y="34"> <parameter key="extract_content" value="true"/> <parameter key="minimum_text_block_length" value="500"/> <parameter key="override_content_type_information" value="true"/> <parameter key="neglegt_span_tags" value="true"/> <parameter key="neglect_p_tags" value="true"/> <parameter key="neglect_b_tags" value="true"/> <parameter key="neglect_i_tags" value="true"/> <parameter key="neglect_br_tags" value="true"/> <parameter key="ignore_non_html_tags" value="true"/> </operator> <connect from_port="document" to_op="Extract Information (2)" to_port="document"/> <connect from_op="Extract Information (2)" from_port="document" to_op="Extract Content (2)" to_port="document"/> <connect from_op="Extract Content (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <connect from_op="Read Excel (2)" from_port="output" to_op="Get Pages (2)" to_port="Example Set"/> <connect from_op="Get Pages (2)" from_port="Example Set" to_op="Process Documents from Data (2)" to_port="example set"/> <connect from_op="Process Documents from Data (2)" from_port="example set" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
@b00122599,
It seems that your Excel file is broken. I can not open it with Excel and I cannot load the file in RapidMiner...
Can you share directly the links here ?
Regards,
Lionel
Regards,
Lionel
@b00122599,
Yes it's strange.
To extract the relevant informations, I proceeded in 2 steps.
But I'm not able to join the 2 resultings example sets (RapidMiner is raising an error).
Anyway, you can take a look at this process, your information ("Text what I want") is in the second resulting example set...
Hope this helps,
Regards,
Lionel
Yes it's strange.
<?xml version="1.0" encoding="UTF-8"?><process version="9.5.000"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.5.000" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="read_excel" compatibility="9.5.000" expanded="true" height="68" name="Read Excel (2)" width="90" x="45" y="85"> <parameter key="excel_file" value="C:\Users\Lionel\Downloads\'snookersmall.xlsx'"/> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"/> <parameter key="read_not_matching_values_as_missings" value="true"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="web:retrieve_webpages" compatibility="9.0.000" expanded="true" height="68" name="Get Pages (2)" width="90" x="179" y="85"> <parameter key="link_attribute" value="LINKS"/> <parameter key="random_user_agent" value="false"/> <parameter key="user_agent" value="googlebot"/> <parameter key="connection_timeout" value="10000"/> <parameter key="read_timeout" value="10000"/> <parameter key="follow_redirects" value="true"/> <parameter key="accept_cookies" value="none"/> <parameter key="cookie_scope" value="global"/> <parameter key="request_method" value="GET"/> <parameter key="delay" value="none"/> <parameter key="delay_amount" value="1000"/> <parameter key="min_delay_amount" value="0"/> <parameter key="max_delay_amount" value="1000"/> </operator> <operator activated="true" breakpoints="after" class="text:process_document_from_data" compatibility="8.2.000" expanded="true" height="82" name="Process Documents from Data (2)" width="90" x="380" y="85"> <parameter key="create_word_vector" value="true"/> <parameter key="vector_creation" value="TF-IDF"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <parameter key="select_attributes_and_weights" value="false"/> <list key="specify_weights"/> <process expanded="true"> <operator activated="true" class="text:extract_information" compatibility="8.2.000" expanded="true" height="68" name="Extract Information (2)" width="90" x="45" y="34"> <parameter key="query_type" value="XPath"/> <list key="string_machting_queries"/> <parameter key="attribute_type" value="Nominal"/> <list key="regular_expression_queries"/> <list key="regular_region_queries"/> <list key="xpath_queries"> <parameter key="Snookname" value="//h:div[1]/h:h1/text()"/> <parameter key="Titleswon" value="//h:div[2]/h:div/h:ul/h:li[1]/h:div"/> </list> <list key="namespaces"/> <parameter key="ignore_CDATA" value="true"/> <parameter key="assume_html" value="true"/> <list key="index_queries"/> <list key="jsonpath_queries"/> </operator> <operator activated="true" class="web:extract_html_text_content" compatibility="9.0.000" expanded="true" height="68" name="Extract Content (2)" width="90" x="179" y="34"> <parameter key="extract_content" value="true"/> <parameter key="minimum_text_block_length" value="1"/> <parameter key="override_content_type_information" value="true"/> <parameter key="neglegt_span_tags" value="true"/> <parameter key="neglect_p_tags" value="true"/> <parameter key="neglect_b_tags" value="true"/> <parameter key="neglect_i_tags" value="true"/> <parameter key="neglect_br_tags" value="true"/> <parameter key="ignore_non_html_tags" value="true"/> </operator> <connect from_port="document" to_op="Extract Information (2)" to_port="document"/> <connect from_op="Extract Information (2)" from_port="document" to_op="Extract Content (2)" to_port="document"/> <connect from_op="Extract Content (2)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="multiply" compatibility="9.5.000" expanded="true" height="103" name="Multiply" width="90" x="514" y="85"/> <operator activated="true" class="select_attributes" compatibility="9.5.000" expanded="true" height="82" name="Select Attributes" width="90" x="659" y="34"> <parameter key="attribute_filter_type" value="subset"/> <parameter key="attribute" value="Titleswon"/> <parameter key="attributes" value="LINKS|Titleswon"/> <parameter key="use_except_expression" value="false"/> <parameter key="value_type" value="attribute_value"/> <parameter key="use_value_type_exception" value="false"/> <parameter key="except_value_type" value="time"/> <parameter key="block_type" value="attribute_block"/> <parameter key="use_block_type_exception" value="false"/> <parameter key="except_block_type" value="value_matrix_row_start"/> <parameter key="invert_selection" value="false"/> <parameter key="include_special_attributes" value="false"/> </operator> <operator activated="true" class="text:generate_extract" compatibility="8.2.000" expanded="true" height="68" name="Generate Extract" width="90" x="793" y="34"> <parameter key="source_attribute" value="Titleswon"/> <parameter key="query_type" value="Regular Expression"/> <list key="string_machting_queries"/> <parameter key="attribute_type" value="Nominal"/> <list key="regular_expression_queries"> <parameter key="Titleswon_2" value="</svg>(.*?)</div>"/> </list> <list key="regular_region_queries"/> <list key="xpath_queries"/> <list key="namespaces"/> <parameter key="ignore_CDATA" value="true"/> <parameter key="assume_html" value="true"/> <list key="index_queries"/> <list key="jsonpath_queries"/> </operator> <connect from_op="Read Excel (2)" from_port="output" to_op="Get Pages (2)" to_port="Example Set"/> <connect from_op="Get Pages (2)" from_port="Example Set" to_op="Process Documents from Data (2)" to_port="example set"/> <connect from_op="Process Documents from Data (2)" from_port="example set" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Select Attributes" to_port="example set input"/> <connect from_op="Multiply" from_port="output 2" to_port="result 1"/> <connect from_op="Select Attributes" from_port="example set output" to_op="Generate Extract" to_port="Example Set"/> <connect from_op="Generate Extract" from_port="Example Set" to_port="result 2"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
Hope this helps,
Regards,
Lionel
1 - 1 of
11
Neil,
I forgot to mention : The relevant informations are extracted in the attribute "Titleswon_2".
The informations are not visible at first sight.. You must leave the mouse on it :
Regards,
Lionel
Regards,
Lionel
In order we can find a solution can you please share :
- your process
- your data (a priori your excel file where your links are stored)
Regards,
Lionel
