question marks in linear regression output
I ran a linear regression model with 18 independent variables and feature selection turned off. For some of the independent variables there were question marks for the standard error of the estimate, and therefore for the t-statistic and p-value for the coefficient. I ran the mode again with feature selection turned on and got the same question marks. What do these question marks mean? Thay cannot have anything to do with missing values as the regression would not have run to completion in that case. I am baffled about what these "?" symbols might mean. Help.....
1 - 12 of
121
Telcontar120
New Altair Community Member
Can you post your process xml? Do you have the bias parameter checked in the LR operator or the exclude collinear features? There are several options that can affect the output.
Hi, I have attached my process rmp file. the 'exclude collinear features' is unchecked. and you are correct about the bias thing. if 'use bias' is checked, i do not get question marks. if it is unchecked, i do get question marks. I did all this with 'feature selection' turned off. Something else is also strange. I then turned on feature selection and used T_Test as the selection method with alpha set to 0.05. I got a solution that included Independent variables with p-value much much higher than 0.05. I am confused why these IVs were not trimmed from the output. thanks in advance for your help.
hi @AD2019 do you mean these ? marks?
So the simple answer is that ? marks are used in RapidMiner when values are missing. The better question is why are they missing...my educated guess here (pls correct me @varunm1 @mschmitz if my stats are wrong here) is that there can be no std coefficient or tolerance for an intercept of a LinReg model as it's a computed value. All of your actual data (the other attributes) have std coefficients which make sense. But my stats are a wee bit rusty so I look to these other smart folks to correct me.
Scott
Scott
Hi Scott:
if you run the process with bias turned off, you will get questions marks for some of the independent variables as well, not just the intercept. Since there is a question mark on the standard error for these variables, the t-statistic and p-values also have question marks on them. So it is not just an issue of the intercept. The data set does not have missing values, so I could not figure out what the question marks were trying to say. The only thing I could think of was numerical overflow or underflow when calculating the standard error of the associated variable, but then I could not see how the coefficients would have been computed.
Amit
Hello @sgenzer and @AD2019
I tried to look at H2O documentation on linear regression, unfortunately, I found none. For GLM to provide p-values, there is a mandatory parameter selection that H2O recommends to get values without "?" (Unknown)
1. You should uncheck the " Use Regularization" option.
2. You should select "Add intercept"
3. You should select " compute p-values"
4. You should select " remove collinear columns"
If these are set then you will get the p values, std.error, etc without question marks. You will get question marks in this case only when the coefficient is 0.
I will see if I can find any information on linear regression.
1 - 2 of
21
