How to group a dataset based on an attribute
User: "Mahyar"
New Altair Community Member
Updated by Jocelyn
I have a dataset containing two attributes: date time and occupancy number
I want to have the maximum occupancy number in each day( no matter what hour), can anyone help me do this?
1 - 3 of 31
    User: "kayman"
    this can be done with the aggregate operator. You select the attribute to group on and you can then aggregate on sum, count, first , last or whatever is required
    User: "Mahyar"
    OP
    I cannot find out how it works. This is my data, I want to know how I can have each day and the maximum occupancy on a new example set
    User: "lionelderkrikor"
    Hi @Mahyar,
    Within the aggregate operator, You have to set :
    In aggregation attributes  :
        - set Occupancy as aggregation attribute  and select maximum as aggregation function.
    In group by attributes
       -  select DateTime
    You can find in attached file a process to help you.
    Regards,
    Lionel
