🎉Community Raffle - Win $25
Join and Win
KNN with parameter tuning and LOG process....Not getting confusion matrix for all k
User: "vbsingh"
New Altair Community Member
Updated by Jocelyn
I am using KNN for multiclass problem . I am applying optimized grid search  for parameter tuning and using log process for getting every cucle results. But I am getting only accuracy results and different values of K. How can i get the confussion matrix  for all possible values of K in KNN..Please suggest and guide...
1 - 10 of 101
    User: "vbsingh"
    OP
    How to get confusion matrix  for all k values through grid search...
    User: "Telcontar120"
    Accepted Answer
    This isn't possible with the log operator and optimize operator alone, I think you are going to need to use a loop and store the confusion matrix from each model run separately.
    User: "vbsingh"
    OP
    But I need parameter optimization too...
    User: "varunm1"
    Accepted Answer
    Hello @vbsingh
    If you are just optimizing on K-Value, please look at the below process, where there are a couple of macros and store operators to store performance in the repository folder. This way, you can store the performance of each k value. You can import the process attached to your RM and change the store operator repository entry, but be sure to add the macro name in the current process of the store operator in the name.
    User: "vbsingh"
    OP
    Great I am trying it......
    User: "varunm1"
    Accepted Answer
    @vbsingh by the way, uncheck the "enable parallel execution" in optimize parameter operator.
    User: "vbsingh"
    OP
    plz send the .properties file also
    User: "varunm1"
    Here is the zip folder with all the related files, you just need to unzip in your local repository of rapidminer folder and run it.
    User: "vbsingh"
    OP
    Hi varunm1,
    Thanks for sharing your operator.. It was great help. But i have one problem with J48 since there is two parameter ...so there is overlapping in result.. how to change the name of the result..and get entire result.
    User: "vbsingh"
    OP
    What should be the range for J48 machine learning technique while using optimize operator
