depandancy element
oggy
oggy Altair Community Member
edited October 2020 in Community Q&A
Hello !!
How can i apply correction manually for a element who have dependency because when i apply a automatic correction HM unrealized all the connectors . any idea plz
Welcome!
Answers
  • Rahul_P1
    Rahul_P1
    Altair Employee
    edited February 2015
    See http://forum.altairhyperworks.com/index.php?/topic/13885-a-dependent-dof-defined-more-than-once-in-rigid-element-error/?hl=dependency#entry20070
    Go to rigids > update sub-panel > check connectivity option > select the element whose double dependency you wish to remove, click on update > unselect the double dependent nodes and click on update.
  • oggy
    i don't have dependency between rigid element but between seam weld
  • Altair Forum User
    Altair Forum User
    Altair Employee
    edited August 2015
    Hi, I am trying to make my double dependent rigids, non-double dependent, but when I select my double dependent node (by left mouse button clicking it I presume) and then click update, it just automatically unselects it and nothing happens. I'm struck dumb with this problem and haven't been able to solve it for the past 3 days. Any suggestions would be more than welcome!
  • tinh
    tinh Altair Community Member
    edited August 2015
    Hi,
    -  enter 1D>rigid>update
    - select 'connectivity'
    - pick on an element, its dependent nodes will be white
    - looking for white nodes that is common between 2 or more rigid elements
    - deselect those nodes by right click on it
    - then press update. the element will be update
    if you press update right after picking on an element, it updates nothing
Welcome!
Welcome!
