1 - 5 of
51
Hello @Napasco
Currently, rapidminer doesn't support IMMI (image classification) third party extensions and they are highly unstable and there is no built-in image processing tool as well. I recommend using AWS rekognition or another third-party API.
You can also convert your images into CSV files and use for analysis or use python scripting in rapidminer to access backend python for image-related processing.
Hello @Napasco
You can do it with simple python code. Sorry, I am currently working on a deadline. You can see below kaggle discussion that helps you.
https://www.kaggle.com/c/digit-recognizer/discussion/33384
http://splab.cz/en/download/software/immi-rapidminer-extenison
http://www.burgsys.com/image-analysis-software.php
