Prediction Analysis of text documents
New Altair Community Member
Updated by Jocelyn
The same process was giving results before but now its showing to 'set role' but as I am using text files I do not know how to solve this problem.
1 - 8 of
81
Hello @lambamanika07
Are you getting an error after running the process? If not, this is just a warning.
@lionelderkrikor can help if you provide data and process file as he requested.
Hi @lionelderkrikor
As suggested by you, I performed the process with 441 full text files but the following error is showing. Kindly suggest how to overcome this.
@lambamanika07,
Based on the error you sent in PM (which is more explicit), can you set in the Split Validation operator parameters, set sampling type = shuffled sampling (instead automatic) ?
Regards,
Lionel
Regards,
Lionel
1 - 1 of
11
@lambamanika07,
Regards,
Lionel
Regards,
Lionel
Can you please attach here in the forum :
- your data
- your process (via File -> Export Process)
Can you precise what you want to do ?
Thanks,
Regards,
Lionel
