My system has 16 Gb of RAM and also Graphic Card. When I ran some process it has you have not enough memory. Is there any way to configure your RapidMiner with your System RAM and GPU.
From my understanding, currently the GPU is for Deep learning, this can be set in Settings --> Preferences --> General --> Deep Learning Back end (CPU or GPU). You can also, try to limit the memory consumption by going to Settings --> Preferences --> System and set the Maximum amount of memory limit based on your RAM. Try this and check if this helps.
