Special characters in a TXT data file
Hi,
In one of our data sets, we have the names of people that contain special characters (like: á, é, ó) and they get translated to multiple character values that skew the data in that row. For example:
Value in the .TXT file contains: László
Value when added to Monarch is: László
And the fields afterwards get pushed over by 2 spaces and that record is ignored. I cannot figure out a trap that will work to include this value.
Is there a setting that can be adjusted or a way to fix this problem?
Hi Denise,
Have you tried to change the character set encoding, for example to UTF-8 encoding?
Monarch Classic: Home -> Options -> Input -> Text FilesData Prep Studio: Settings (on Report Design view) -> Input
The default is to use ANSI encoding. Using @Lasse suggestion to change the encoding type to UTF-8 should resolve your issue.
Hi Lasse,
I kept working on this problem after posting and found that if I saved the TXT file from UTF-8 to ANSI worked, so I was very happy. Now I just tried your suggestion and that's even better since I won't be the one using this workspace daily. I'm new to Monarch so I really appreciate your quick help, genius!
Regards, Denise
Hi Lasse,
Regards, Denise
Hi Denise,
Are you working with reports from Ellucian Banner or Colleague? Or another ERP system?
We're building a library of pre-built templates for those systems and others in our Monarch Model Library.
If you don't see a system you work with on that list let us know and we'll add it to the list.
Hi Denise,
Hi Denise,
