🎉Community Raffle - Win $25
Join and Win
how can i uninstall the rapidminer server
User: "lzu"
New Altair Community Member
Updated by Jocelyn
i installed the rapidminer server on the centos 7 .
then i want to reinstall it
how can i uninstall the rapidminer server ?
1 - 10 of 101
    User: "BalazsBaranyRM"
    Hi!
    The RM Server installation changes the following things:
    - RapidMiner Server installation directory
    - RapidMiner Server home directory
    If you installed startup scripts (/etc/init.d, or /etc/systemd/system), remove these.
    If you installed job agents in a path of your choosing, also delete these.
    You can also delete the backend database in your database server.
    Regards,
    Balázs
    User: "mmichel"
    Thanks Balázs,
    we will also consider to add this to our documentation articles.
    Cheers,
    Marcel
    User: "lzu"
    OP
    Thanks Marcel and Balázs,
    I have reinstalled RM server , and no errors .
    but when  i startup it,  other errors have occurred.
    1.the server is trying to connect to an activeMQ server ,but time out , Do I need to start an activeMQ server before I start the RM server ?
    2.Some error messages show that some of the tables on mysql don't exist, but I don't see the part of the table in the document, how do I create tables in mysql?
    I don't speak english very well, I hope you can understand what I mean.
    LiuWenlong , a Chinese student at LanZhou University
    User: "lzu"
    OP
    10:32:49,937 ERROR [org.jboss.msc.service.fail] (MSC service thread 1-10) MSC000001: Failed to start service jboss.network.management: org.jboss.msc.service.StartException in service jboss.network.management: JBAS015810: failed to resolve interface management
            at org.jboss.as.server.services.net.NetworkInterfaceService.start(NetworkInterfaceService.java:103) [jboss-as-server-7.5.0.Final-redhat-15.jar:7.5.0.Final-redhat-15]
            at org.jboss.msc.service.ServiceControllerImpl$StartTask.startService(ServiceControllerImpl.java:1980) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
            at org.jboss.msc.service.ServiceControllerImpl$StartTask.run(ServiceControllerImpl.java:1913) [jboss-msc-1.1.5.Final-redhat-1.jar:1.1.5.Final-redhat-1]
            at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [rt.jar:1.8.0_152]
            at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [rt.jar:1.8.0_152]
            at java.lang.Thread.run(Thread.java:748) [rt.jar:1.8.0_152]
    User: "mmichel"
    Hi LiuWenlong,
    The ActiveMQ Broker should start automatically with RapidMiner Server. For troubleshooting please upload the server.log file (you can find this one in the log directory of the server home).
    This messages should only appear during the first start of RapidMiner Server and indicate the creation of the tables. So, no manual steps required on your end.
    Cheers,
    Marcel
    User: "lzu"
    OP
    Updated by lzu
    thanks Marcel,
    i upload my server.log and RMS_installer.xml ,Some of RMS_installer.xml been hidden by me.
    now i installed RM server ,but when i trying to start is, The startup script stays at the server.log display,
    The startup script stays at the server.log display,  and i can`t access   myhost:8080 .
    i trying to access myhost:9990 ,i see 'Welcome to JBoss EAP 6' , Looks like the jBoos server is already started.
    and here's the tables that mysql automatically created.
    I can't find the tables that appear in the error log in the database.
    What am I supposed to do now ?
    Thanks again,
    LiuWenlong
    User: "mmichel"
    Accepted Answer
    Hi LiuWenlong,
    the table creation seems to fail:
    15:22:19,660 ERROR [org.hibernate.tool.hbm2ddl.SchemaUpdate] (ServerService Thread Pool -- 64) HHH000388: Unsuccessful: create table ra_ent_group (groupName varchar(255) not null, assignToNewUsers boolean not null, description varchar(255), mirror boolean, singleton boolean not null, special boolean not null, primary key (groupName))
    due to
    Specified key was too long; max key length is 767 bytes
    What DB version are you using? I guess MySQL 5.6 in combination with utf8mb4 encoding? Sadly this configuration will not work out of the box. The best way to overcome this limit would be to use the latest MySQL 5.7 Server or to use another encoding.
    Hope this helps,
    Marcel
    User: "lzu"
    OP
    thanks Marcel,
    I changed the encoding to GBK, it worked, thank you very much for your help.
    LiuWenlong
    User: "sharki"
    Hi Izu, i have the exact same Error like you. what do you mean with "changing the endocding to GBK"?
    Kind regards
    User: "aschaferdiek"
    Updated by aschaferdiek
    Hi. You can change/set the encoding of a database/schema of MySQL. GBK is the encoding for simplified chinese. In general it's advised that you use an up-to-date MySQL version which is supported and the UTF8 encoding.
    Could you also provide your server.log file so we can see more details?
