After Nominal to Text and Loop Collection, the date column gone
Titzaaa
Titzaaa New Altair Community Member
edited November 2024 in Community Q&A
Hi everyone,
when doing some text mining, I would like to know the date of each article after tokenization. However, I only receive the text columns in the end, on which the sentiment dictionary is applied. Is there any possibility to keep the date column or add it again on the way?
Here is my code:
<context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.3.001" expanded="true" name="Process">
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <process expanded="true">
      <operator activated="true" class="retrieve" compatibility="9.3.001" expanded="true" height="68" name="Retrieve" width="90" x="45" y="34">
        <parameter key="repository_entry" value="../Data/Lexis_Nexis_PAT"/>
      </operator>
      <operator activated="true" class="retrieve" compatibility="9.3.001" expanded="true" height="68" name="Retrieve (2)" width="90" x="45" y="289">
        <parameter key="repository_entry" value="../Data/GRESD"/>
      </operator>
      <operator activated="true" class="operator_toolbox:dictionary_sentiment_learner" compatibility="2.0.001" expanded="true" height="82" name="Dictionary-Based Sentiment (Documents)" width="90" x="246" y="289">
        <parameter key="value_attribute" value="Klassifizierung"/>
        <parameter key="key_attribute" value="Wort"/>
        <parameter key="negation_attribute" value="Negationen"/>
        <parameter key="negation_window_size" value="5"/>
        <parameter key="use_symmetric_negation_window" value="true"/>
      </operator>
      <operator activated="true" class="set_role" compatibility="9.3.001" expanded="true" height="82" name="Set Role" width="90" x="112" y="187">
        <parameter key="attribute_name" value="Datum"/>
        <parameter key="target_role" value="Datum"/>
        <list key="set_additional_roles"/>
      </operator>
      <operator activated="true" class="nominal_to_text" compatibility="9.3.001" expanded="true" height="82" name="Nominal to Text" width="90" x="179" y="34">
        <parameter key="attribute_filter_type" value="subset"/>
        <parameter key="attribute" value="Body Teil 1"/>
        <parameter key="attributes" value="|Body Teil 1|Body Teil 2"/>
        <parameter key="use_except_expression" value="false"/>
        <parameter key="value_type" value="nominal"/>
        <parameter key="use_value_type_exception" value="false"/>
        <parameter key="except_value_type" value="file_path"/>
        <parameter key="block_type" value="single_value"/>
        <parameter key="use_block_type_exception" value="false"/>
        <parameter key="except_block_type" value="single_value"/>
        <parameter key="invert_selection" value="false"/>
        <parameter key="include_special_attributes" value="false"/>
      </operator>
      <operator activated="true" class="text:data_to_documents" compatibility="8.2.000" expanded="true" height="68" name="Data to Documents" width="90" x="313" y="34">
        <parameter key="select_attributes_and_weights" value="false"/>
        <list key="specify_weights"/>
      </operator>
      <operator activated="true" class="loop_collection" compatibility="9.3.001" expanded="true" height="82" name="Loop Collection" width="90" x="447" y="34">
        <parameter key="set_iteration_macro" value="false"/>
        <parameter key="macro_name" value="iteration"/>
        <parameter key="macro_start_value" value="1"/>
        <parameter key="unfold" value="false"/>
          <operator activated="true" class="text:tokenize" compatibility="8.2.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="45" y="34">
            <parameter key="mode" value="non letters"/>
            <parameter key="characters" value=".:"/>
            <parameter key="language" value="English"/>
            <parameter key="max_token_length" value="3"/>
          </operator>
          <operator activated="true" class="text:transform_cases" compatibility="8.2.000" expanded="true" height="68" name="Transform Cases (2)" width="90" x="179" y="34">
            <parameter key="transform_to" value="lower case"/>
          </operator>
          <operator activated="true" class="text:filter_stopwords_german" compatibility="8.2.000" expanded="true" height="68" name="Filter Stopwords (2)" width="90" x="313" y="34">
            <parameter key="stop_word_list" value="Standard"/>
          </operator>
          <operator activated="true" class="text:filter_by_length" compatibility="8.2.000" expanded="true" height="68" name="Filter Tokens (2)" width="90" x="514" y="34">
            <parameter key="min_chars" value="3"/>
            <parameter key="max_chars" value="10000"/>
          </operator>
          <connect from_port="single" to_op="Tokenize (2)" to_port="document"/>
          <connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases (2)" to_port="document"/>
          <connect from_op="Transform Cases (2)" from_port="document" to_op="Filter Stopwords (2)" to_port="document"/>
          <connect from_op="Filter Stopwords (2)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
          <connect from_op="Filter Tokens (2)" from_port="document" to_port="output 1"/>
          <portSpacing port="source_single" spacing="0"/>
          <portSpacing port="sink_output 1" spacing="0"/>
          <portSpacing port="sink_output 2" spacing="0"/>
        </process>
      </operator>
      <operator activated="true" class="operator_toolbox:apply_model_documents" compatibility="2.0.001" expanded="true" height="103" name="Apply Model (Documents)" width="90" x="581" y="187">
      </operator>
      <operator activated="true" class="generate_attributes" compatibility="9.3.001" expanded="true" height="82" name="Generate Attributes" width="90" x="715" y="187">
        <list key="function_descriptions">
          <parameter key="#Pos_Wörter/(#Pos_Wörter+#Neg_Wörter)" value="Positivity/(Positivity-Negativity)"/>
          <parameter key="#Neg_Wörter/(#Pos_Wörter+#Neg_Wörter)" value="Negativity*-1/(Negativity*-1+Positivity)"/>
          <parameter key="Pos_Score" value="if(Positivity&gt;(Negativity*-1),1,0)"/>
          <parameter key="Neg_Score" value="if((Negativity*-1)&gt;Positivity,-1,0)"/>
        </list>
        <parameter key="keep_all" value="true"/>
      </operator>
      <operator activated="true" class="generate_attributes" compatibility="9.3.001" expanded="true" height="82" name="Generate Attributes (2)" width="90" x="849" y="187">
          <parameter key="Sentiment_Score" value="if(Pos_Score&gt;0,1,if(Neg_Score&lt;0,-1,0))"/>
        </list>
      </operator>
      <operator activated="true" class="write_excel" compatibility="9.3.001" expanded="true" height="103" name="Write Excel" width="90" x="983" y="187">
        <parameter key="excel_file" value="D:\Franziska C. Weis\Masterarbeit\03 Datenanalyse\Rapid_Miner_Analysis_IZ.xlsx"/>
        <parameter key="file_format" value="xlsx"/>
        <enumeration key="sheet_names"/>
        <parameter key="sheet_name" value="RapidMiner Data"/>
        <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
        <parameter key="number_format" value="#.0"/>
      </operator>
      <connect from_op="Retrieve" from_port="output" to_op="Set Role" to_port="example set input"/>
      <connect from_op="Retrieve (2)" from_port="output" to_op="Dictionary-Based Sentiment (Documents)" to_port="exa"/>
      <connect from_op="Dictionary-Based Sentiment (Documents)" from_port="mod" to_op="Apply Model (Documents)" to_port="mod"/>
      <connect from_op="Set Role" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/>
      <connect from_op="Nominal to Text" from_port="example set output" to_op="Data to Documents" to_port="example set"/>
      <connect from_op="Data to Documents" from_port="documents" to_op="Loop Collection" to_port="collection"/>
      <connect from_op="Loop Collection" from_port="output 1" to_op="Apply Model (Documents)" to_port="doc"/>
      <connect from_op="Apply Model (Documents)" from_port="exa" to_op="Generate Attributes" to_port="example set input"/>
      <connect from_op="Generate Attributes" from_port="example set output" to_op="Generate Attributes (2)" to_port="example set input"/>
      <connect from_op="Generate Attributes (2)" from_port="example set output" to_op="Write Excel" to_port="input"/>
      <connect from_op="Write Excel" from_port="through" to_port="result 1"/>
    </process>
  </operator>
</process>
Welcome!
Answers
Welcome!
Welcome!
