How do i get the username under which a process is executing?
Hi, I am relatively new to RapidMiner and currently using it to load data to RedShift.
I need to log the username under which a process is executing. I will later on log that username and datetime in a log table.
I have trouble getting the username as a macro. I got some reference that I maybe able to use %{_ra_user} but I get an error that _ra_user is unknown. Any guidance or working sample process would be appreciated.
Thank You
Thank You
