🎉Community Raffle - Win $25
Join and Win
Issue in optimize selection
User: "Gauthamk"
New Altair Community Member
Updated by Jocelyn
Hi All
Trying to do Optimize selection feature and getting the attached issue.Any assistance is appreciated
1 - 6 of 61
    User: "Gauthamk"
    OP
    User: "varunm1"
    Updated by varunm1
    Hello @Gauthamk
    Based on your image, we can see that you connected model "mod" and performance "per", this is a wrong connection and you dont need this. Remove it and observe the result.
    Thanks,
    Varun
    User: "Gauthamk"
    OP
    Hi Varun
    i did as per your above message and now still getting the error message in performance operator.Please check attached,
    User: "varunm1"
    Updated by varunm1
    Hello @Gauthamk
    Now you connected "per" to "tes" and "exa" to "per", this should be reversed. "Per" to "per" and "exa" to "tes".
    I recommend you go through some examples on academy to understand the working on these connections.
    User: "Gauthamk"
    OP
    Hi Thank you Varun
    Can you let me know where i can find video links in academy to view for Optimize selection attributes operator
    User: "varunm1"
    Hello @Gauthamk
    Most of the operators in Rapidminer have a tutorial process. Once you click on the operator, in the help window you can see "Jump to tutorial Process". If you click this, you will get a link to the tutorial and you can observe the tutorial process. If you cannot see help window, you need to enable it in View --> Show Panel --> Help
    Hope this helps.
