I'm having a problem in running my process in a Java Application
Hi I'm having errors/warnings with my Java app. Any help would be appreciated.
Here is my code in Netbeans:
RepositoryLocation pLoc = new RepositoryLocation(process); ProcessEntry pEntry = (ProcessEntry) pLoc.locateEntry(); String processXML = pEntry.retrieveXML(); com.rapidminer.Process myProcess = new com.rapidminer.Process(processXML); myProcess.setProcessLocation(new RepositoryProcessLocation(pLoc)); Operator myOperator = myProcess.getOperator("Read Excel - New Data"); RepositoryLocation loc = new RepositoryLocation(upload); IOObjectEntry entry = (IOObjectEntry) loc.locateEntry(); IOObject myIOObject; myIOObject= entry.retrieveData(null); myOperator.setParameter(RepositorySource.PARAMETER_REPOSITORY_ENTRY, upload); IOContainer ioInput = new IOContainer(new IOObject[] {myIOObject}); IOContainer ioResult = myProcess.run(ioInput); if (ioResult.getElementAt(0) instanceof IOObject) { ExampleSet resultSet = (ExampleSet)ioResult.getElementAt(0); jLabelStatus.setText(resultSet.toString());Here is the XML of my process in RapidMiner:
</code><?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve WordList from Trained Model" width="90" x="179" y="34"> <parameter key="repository_entry" value="//Local Repository/Thesis/WL"/> </operator> <operator activated="true" class="read_excel" compatibility="9.2.001" expanded="true" height="68" name="Read Excel - New Data" width="90" x="45" y="136"> <parameter key="excel_file" value="E:\Documents\Thesis\Data\Proto.xlsx"/> <parameter key="sheet_selection" value="sheet number"/> <parameter key="sheet_number" value="1"/> <parameter key="imported_cell_range" value="A1"/> <parameter key="encoding" value="SYSTEM"/> <parameter key="first_row_as_names" value="true"/> <list key="annotations"/> <parameter key="date_format" value=""/> <parameter key="time_zone" value="SYSTEM"/> <parameter key="locale" value="English (United States)"/> <parameter key="read_all_values_as_polynominal" value="false"/> <list key="data_set_meta_data_information"> <parameter key="0" value="Tweet.true.text.attribute"/> <parameter key="1" value="Polarity.true.text.label"/> </list> <parameter key="read_not_matching_values_as_missings" value="false"/> <parameter key="datamanagement" value="double_array"/> <parameter key="data_management" value="auto"/> </operator> <operator activated="true" class="set_role" compatibility="9.2.001" expanded="true" height="82" name="Set Role" width="90" x="179" y="187"> <parameter key="attribute_name" value="Polarity"/> <parameter key="target_role" value="label"/> <list key="set_additional_roles"/> </operator> <operator activated="true" class="text:data_to_documents" compatibility="8.1.000" expanded="true" height="68" name="Data to Documents" width="90" x="313" y="187"> <parameter key="select_attributes_and_weights" value="false"/> <list key="specify_weights"/> </operator> <operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="447" y="136"> <parameter key="create_word_vector" value="true"/> <parameter key="vector_creation" value="TF-IDF"/> <parameter key="add_meta_information" value="true"/> <parameter key="keep_text" value="false"/> <parameter key="prune_method" value="none"/> <parameter key="prune_below_percent" value="3.0"/> <parameter key="prune_above_percent" value="30.0"/> <parameter key="prune_below_rank" value="0.05"/> <parameter key="prune_above_rank" value="0.95"/> <parameter key="datamanagement" value="double_sparse_array"/> <parameter key="data_management" value="auto"/> <process expanded="true"> <operator activated="true" class="text:replace_tokens" compatibility="8.1.000" expanded="true" height="68" name="Replace Tokens" width="90" x="45" y="34"> <list key="replace_dictionary"> <parameter key="@[0-9a-zA-Z]*" value=" "/> <parameter key="#[0-9a-zA-Z]*" value=" "/> <parameter key="(https?|http)://[-a-zA-Z0-9+&@#/%?=~_|!:,.;]*[-a-zA-Z0-9+&@#/%=~_|]" value=" "/> <parameter key="[:=][-)]*[)D]" value="posi "/> <parameter key="[:;=][-(]*[(]" value="nega "/> </list> </operator> <operator activated="true" class="text:transform_cases" compatibility="8.1.000" expanded="true" height="68" name="Transform Cases" width="90" x="112" y="136"> <parameter key="transform_to" value="lower case"/> </operator> <operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="246" y="136"> <parameter key="mode" value="non letters"/> <parameter key="characters" value=".:"/> <parameter key="language" value="English"/> <parameter key="max_token_length" value="3"/> </operator> <operator activated="true" class="text:filter_stopwords_dictionary" compatibility="8.1.000" expanded="true" height="82" name="Filter Stopwords (Dictionary)" width="90" x="313" y="34"> <parameter key="file" value="E:\Documents\Thesis\Data\puurula.txt"/> <parameter key="case_sensitive" value="false"/> <parameter key="encoding" value="SYSTEM"/> </operator> <operator activated="true" class="text:stem_porter" compatibility="8.1.000" expanded="true" height="68" name="Stem (Porter)" width="90" x="447" y="34"/> <operator activated="true" class="text:generate_n_grams_terms" compatibility="8.1.000" expanded="true" height="68" name="Generate n-Grams (Terms)" width="90" x="514" y="136"> <parameter key="max_length" value="2"/> </operator> <connect from_port="document" to_op="Replace Tokens" to_port="document"/> <connect from_op="Replace Tokens" from_port="document" to_op="Transform Cases" to_port="document"/> <connect from_op="Transform Cases" from_port="document" to_op="Tokenize" to_port="document"/> <connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/> <connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_op="Stem (Porter)" to_port="document"/> <connect from_op="Stem (Porter)" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/> <connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/> <portSpacing port="source_document" spacing="0"/> <portSpacing port="sink_document 1" spacing="0"/> <portSpacing port="sink_document 2" spacing="0"/> </process> </operator> <operator activated="true" class="store" compatibility="9.2.001" expanded="true" height="68" name="Store" width="90" x="648" y="85"> <parameter key="repository_entry" value="../Data (ExampleSet)/Proto"/> </operator> <connect from_port="input 1" to_op="Read Excel - New Data" to_port="file"/> <connect from_op="Retrieve WordList from Trained Model" from_port="output" to_op="Process Documents" to_port="word list"/> <connect from_op="Read Excel - New Data" from_port="output" to_op="Set Role" to_port="example set input"/> <connect from_op="Set Role" from_port="example set output" to_op="Data to Documents" to_port="example set"/> <connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/> <connect from_op="Process Documents" from_port="example set" to_op="Store" to_port="input"/> <connect from_op="Store" from_port="through" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="source_input 2" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process> </pre><div>Here is the error/warnings I got:<br><pre class="CodeBlock"><code>May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter parseOperator INFO: The parameter 'create_word_vector' is unknown for operator 'Process Documents' (" dummy ")." May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter parseOperator INFO: The parameter 'vector_creation' is unknown for operator 'Process Documents' (" dummy ")." May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter parseOperator INFO: The parameter 'add_meta_information' is unknown for operator 'Process Documents' (" dummy ")." May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter parseOperator INFO: The parameter 'keep_text' is unknown for operator 'Process Documents' (" dummy ")." May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter parseOperator INFO: The parameter 'prune_method' is unknown for operator 'Process Documents' (" dummy ")." May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter parseOperator INFO: The parameter 'prune_below_percent' is unknown for operator 'Process Documents' (" dummy ")." May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter parseOperator INFO: The parameter 'prune_above_percent' is unknown for operator 'Process Documents' (" dummy ")." May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter parseOperator INFO: The parameter 'prune_below_rank' is unknown for operator 'Process Documents' (" dummy ")." May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter parseOperator INFO: The parameter 'prune_above_rank' is unknown for operator 'Process Documents' (" dummy ")." May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter parseOperator INFO: The parameter 'datamanagement' is unknown for operator 'Process Documents' (" dummy ")." May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter parseOperator INFO: The parameter 'data_management' is unknown for operator 'Process Documents' (" dummy ")." May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter addMessage INFO: <em class="error">Operator '<class>dummy</class>' may not have children. Ignoring. May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter addMessage INFO: <em class="error">The input port <var>word list</var> is unknown at operator <var>Process Documents</var>.</em> May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter addMessage INFO: <em class="error">The input port <var>example set</var> is unknown at operator <var>Data to Documents</var>.</em> May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter addMessage INFO: <em class="error">The output port <var>documents</var> is unknown at operator <var>Data to Documents</var>.</em> May 25, 2019 11:55:58 AM com.rapidminer.io.process.XMLImporter addMessage INFO: <em class="error">The output port <var>example set</var> is unknown at operator <var>Process Documents</var>.</em>
