Node deactivated from interface
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hello,
I use Radioss for a dynamic impact problem, but also for the moment to validate my model through a quasi-static analysis.
A first component compresses a second component with an imposed velocity. The interface between them is of type 7. In dynamic explicit simulation the interface works fine but in the implicit simulation, I get a warning in interface : 'NODE ... DE-ACTIVATED FROM INTERFACE'. If I make an 'initial penetration' (initial gap < gapmin entered into type 7 interface) I do not get this problem (however I get initial constraints I want to avoid).
Would anyone know what the problem might be ?
Hereunder a part of my engine.out file:
 CYCLE    TIME      TIME-STEP  ELEMENT          ERROR  I-ENERGY    K-ENERGY T  K-ENERGY R  EXT-WORK MAS.ERR
     0   0.000      0.2000E+05 SOLID      39426   0.0%   0.000       0.000       0.000       0.000       0.000
     ANIMATION FILE: pression_statique_07A001 WRITTEN
  ***** WARNING : ELEMENT FORMULATION ISOLID=    0
     IS NOT AVAILABLE FOR STIFFNESS MATRIX BUILDING, USING GENERIC ONE INSTEAD
      POSSIBLE CONVERGING ISSUE. *****
   *--------- STIFFNESS MATRIX SETUP ---------*
 SYMBOLIC DIM : ND =  155532 NZ =   2897175 NB_MAX =      26
 FINAL    DIM : ND =   47480 NZ =    761383 NB_MAX =      26
     --STIFFNESS MATRIX WILL BE REFORMED AFTER EACH    3  ITERATIONS--
   * CONVERGED WITH    0 ITERATIONS, |du|/|u|,|r|/|r0|,|dE|/|E|= 0.1000E+01 0.0000E+00 0.1000E+01
 WARNING INTERFACE        701
 NODE      13703 DE-ACTIVATED FROM INTERFACE
 NODE      13548 DE-ACTIVATED FROM INTERFACE
 NODE      13693 DE-ACTIVATED FROM INTERFACE
     ANIMATION FILE: pression_statique_07A002 WRITTEN
   * IMPLICIT COMPUTATION TERMINATED WITH    TOTAL NONLINEAR ITERATIONS:       0
   * TOTAL NUM.OF MATRIX FACTORIZATION AND PCG ITERATION:      0         0
     RESTART FILES: pression_statique_07_0001_[0001-0001].rst WRITTEN
                           ** CPU USER TIME **
 #PROC  [K]SETUP [M]SETUP IMPL.SOLV IMPL.TOTAL
   1   .4862E+02 .0000E+00 .0000E+00 .4930E+02
 #PROC  CONT.SORT  CONT. F   ELEMENT  KIN.COND.  INTEGR.    I/O     TASK0     ASSEMB.   RESOL
   1   .5591E-01 .6813E-02 .2678E+00 .2133E-01 .4654E-03 .5012E+00 .9117E-03 .1199E-01 .5030E+02
Thank you a lot,
Kinds regards,
Alice
1 - 9 of 91
    Altair Employee
    OP
    Hi Alice,
    As a workaround, can you set the Irem_gap as 1 in interface parameters and run the analysis. Please update
    Altair Employee
    OP
    Hello George,
    Thanks for your quick reply. I did not see it right away.
    I solved my problem of slave nodes deactivation by initiating the implicit time step (/IMPL/DTINI). I tried setting Irem_gap to 1 but it did not change the fact that the interface is not taken into account.
    Now, there isn't even an error. No slave node is deactivated but the animation shows a penetration. I constantly change the parameters in the interface as well as in the engine implicit options. But I don't manage to solve the issue of penetration. I have performed a checking of the implicit model, giving two warnings :
    and
      ** WARNING :IMPLICIT LOADING DATA **
    Concerning the first warning, I first used the /IMPLICIT option ni the control cards but this gave me a lot of errors as Isolid= 14 in implicit default options and this is not compatible with tetra mesh. So I set it back to the generally default '0' value but it might give 'converging issues'. Would you know how I can manage this problem ? And if this might cause m y problem of penetration without errors ?
    Concerning the second warning, I don't understand its meaning, nore did I find any help in the forum about this.
    Please find attached my engine out file for the implicit checking computation.
    Thank you in advance for helping me out.
    Alice
    Altair Employee
    OP
    Hi Alice,
    Can you try with a different element formulation and see whether the warning is still there?. Normally for 4 node solid tetrahedron there is a drawback of  low convergence. As a workaround, I can suggest you to use 10 node solid tetrahedron element and check.
     In some cases, RADIOSS does not detect any loading upon part and stops supposing that the input was false.
    The suggested workarounds for this issue are:
    1.Check loading in the model.
    2.Increase the initial time step.
    3.Creating a slight contact penetration in cases where loading is due to contact.
    Altair Employee
    OP
    Hello George,
    Thank you for your quick reply.
    I have already tried different element formulations but nothing works.
    I indeed have 4-node tetrahedron elements. I tried yesterday to change them to 10-node tetrahedrons but did not find how to choose this. How can I tell Hypermesh I want 10-node tetrahedrons ? In a video I saw that Hypermesh gives the choice of first and second order tetra elements but I do not have this choice (see attached word document).
    Concerning the second warning: my loading consists of a first component compressing a second one; so indeed I have a loading created through contact. In my first simulations I had initial penetration of the contact gap without purpose. This made it work but I have one major problem with this: I have initial loading and this is clearly an outlying result (10^5 N at t = 0, when having 150 N after 0,2 mm compression during real testings).
    My initial timestep is of 10 for the moment (/IMPL/DTINI = 10), I will set it higher and come back to you.
    Thanks again,
    Alice
    Altair Employee
    OP
    Hi Alice,In 3D panel, you will get Order Change option where this function can be used to change a group of elements from first  order elements to second  order elements.
    Altair Employee
    OP
    Hello George,
    I managed to change tetra4 -> Brick (degenerated tetrahedron) by unchecking the 'match existing mesh box'. But would still be interested in knowing how to mesh in tetra10.
    I changed Isolid to 17 (what to me seems best) and then to 14 (implicit default value) and both warnings disappear.
    However my problem remains...
    I will come back to you after having checked a higher inital time step and slight initial penetration.
    Altair Employee
    OP
    Hi Alice,
    Which HyperWorks version you are using?.In Help Menu>>Click on Updates and System Information and please attach a screen shot of it.
    Altair Employee
    OP
    Hello Geroge,
    Thank yo ufor the help on second order elements. I am currently running the simulation on tetra10 and will come back to you on this.
    Find attached the screenshot of the updates information. I use version 14.0
    Altair Employee
    OP
    Hi Alice,
    Please update to the latest version HyperWorks 14.0.130.
    For the time being, you can use Order Change option to  change from first  order elements to second  order elements.
