🎉Community Raffle - Win $25
Join and Win
how applying sub processes on my data set depending upon the performance value?
User: "armina"
New Altair Community Member
Updated by Jocelyn
1 - 4 of 41
    User: "varunm1"
    Hello @armina
    Can you please explain in detail? Which subprocess? What kind of dataset and what you are trying to do now?
    Thanks,
    Varun
    User: "armina"
    OP
    Thank you
    I have data from Android malware and I want the model to enter the second phase of machine learning if the performance of the first machine is low. How can I do this?
    User: "lionelderkrikor"
    Hi @armina,
    I think you can take a look at the OPERATIONALIZATION template process of RapidMiner. You can access to this process via File -> New Process.
    Hope this helps,
    Regards,
    Lionel
    User: "Telcontar120"
    You can also look at the Branch operator or Handle Exception operator, both of which provide the ability to do IF....THEN type logic.  Depending on exactly what you want to do they may be suitable.
