Applying association rules block
Hello
so i am trying to apply the association rules i have generated on a test set but i am getting the following:
- Exception: com.rapidminer.example.AttributeTypeException
- Message: Attribute [1] {1=0} is not a classification attribute!
- Stack trace:
- com.rapidminer.example.table.PolynominalMapping.ensureClassification(PolynominalMapping.java:241)
- com.rapidminer.example.table.PolynominalMapping.getPositiveIndex(PolynominalMapping.java:174)
- com.rapidminer.operator.associations.AssociationRulesApplier.doWork(AssociationRulesApplier.java:109)
- com.rapidminer.operator.Operator.execute(Operator.java:1026)
- com.rapidminer.operator.execution.SimpleUnitExecutor.execute(SimpleUnitExecutor.java:77)
- com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:812)
- com.rapidminer.operator.ExecutionUnit$2.run(ExecutionUnit.java:807)
- java.security.AccessController.doPrivileged(Native Method)
- com.rapidminer.operator.ExecutionUnit.execute(ExecutionUnit.java:807)
- com.rapidminer.operator.OperatorChain.doWork(OperatorChain.java:423)
- com.rapidminer.Process.executeRoot(Process.java:1386)
- com.rapidminer.Process.execute(Process.java:1327)
- com.rapidminer.Process.run(Process.java:1300)
- com.rapidminer.Process.run(Process.java:1186)
- com.rapidminer.Process.run(Process.java:1139)
- com.rapidminer.Process.run(Process.java:1134)
- com.rapidminer.Process.run(Process.java:1124)
- com.rapidminer.gui.ProcessThread.run(ProcessThread.java:65)
1 - 4 of
41
XML Code
Hello @ZAM
Did you share the correct XML? I see that the XML and screenshot you gave are different. Can you check once again?
Thanks
Varun
Thanks
Varun
Hello @ZAM,
I tried looking at the process and it seems fine but without data, I cannot understand why this error is encountered during process execution.
Thanks
Varun
Thanks
Varun
1 - 1 of
11
Hello @ZAM,
Thanks
Varun
Thanks
Varun
