Tableau
Hello
@rfuentealba
Look at the screen shot please. I can not use Tableau and also is it possible to use Tableau for visualize the result of our process instead of plot view?
Thank you
@rfuentealba
Thank you
1 - 14 of
141
hello @mbs this is the link you want
https://docs.rapidminer.com/latest/studio/how-to/data-export/tableau.html
Scott
Scott
@sgenzer
thank you for your answer but please help me to solve the problem which I show that on the previous screen shot
Hello @mbs
Did you follow the exact steps mentioned in the URL link provided by @sgenzer during the installation of this extension?
These steps are really important and should be done in a sequence as mentioned in the URL. There might be some installation issue that is throwing this error.
Regards,
Varun
Regards,
Varun
Hello @mbs
You need to do it with predictions from your model. You can go through the below video for a clear understanding of how both RM and Tableau are used.
https://rapidminer.com/resource/better-together-minimizing-machine-failure-rapidminer-tableau/
Hope this helps.
Thanks,
Varun
Hope this helps.
Thanks,
Varun
Hello @mbs
Are you asking, if you could visualize the model performances like accuracy, AUC, ROC Curve, etc directly in Tableau?
Got it. I don't think you can directly see the results like AUC, ROC curves in Tableau as it takes example set (Data).
@M_Martin any suggestions.
@varunm1
some times the result of plot view is not that much clear so I think if we can show the result of our process in Tableau it is more clear and also more useful
regards
mbs
regards
mbs
Most of the time when I search any thing some links like these two links do not work
please help me to solve them.
regards
mbs
