Compression test
Hi all, I have to simulate a compression test of a structure between two rigid plates and i have some questions.
Is it worth considering plates and structures as an unique component or a better solution is to create different component, with different properties (high E module for rigid for plates)?
Also when the upper plate comes down, at the interface between plate and structure, structure could present a horizontally displacement, caused by deformation. How I cold simulate this type of contact?
Thank you all.
