Altair RISE
Nominate Yourself Now!
interpenetration
User: "LucaC"
Altair Community Member
Updated by LucaC
Hi all,
is there some way to disable interpenetration between elements of a component?
Thank you all
1 - 11 of 111
    User: "Adriano_Koga"
    Altair Employee
    Updated by Adriano_Koga
    if ?I understood correctly your question, you want to avoid elements to penetrate each other?
    If that's the case, you need to specify contacts between your parts. If it is in the same part, then, self-contact is needed:
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.ee228206c26c6d89e54e8a83f4accf5a.png
    If it is only related to meshing issues, HM has the 'penetration check' panel (Ctrl+F >> penetration)
    User: "LucaC"
    OP
    Updated by LucaC
    Thank you.
    My problem is related to a penetration during a compression test. Where I can find this tutorial?
    Altair Employee
    You need to launch the Help, going in the toolbar Help>>Altair Help Home
    Then navigate to OptiStruct Section.
    There will be then tutorials page.
    Or try typing the tutorial code or name into the Help search.
    I suggest you to look at Altair University and go through a couple non-linear analysis tutorials.
    User: "LucaC"
    OP
    Updated by LucaC
    Thank you. I look for that tutorial, but I didn't find it, then i lok for other tutorial
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.ad4f9af3b986216e2b7cb23f54eed42d.png
    When i run the simulation i get this advice. I created contactsurf with solid faces option. I select the so created contact both for SSID and MSID
    User: "LucaC"
    OP
    Updated by LucaC
    That's how i create the contactsurf
    Here the interfaces panel
    I need no penetration during a compression test
    User: "LucaC"
    OP
    Updated by LucaC
    If you need, here is the model
    Altair Employee
    What version o OptiStruct are you using?
    Self-contact is available from OS 2017.something (maybe.2)
    These are the tutorials from the Help.
    User: "LucaC"
    OP
    Updated by LucaC
    I'm using Hypermesh 2019.1
    Could you link me the hm model of OS-T_1540 ?
    I'm following the guide you linked me, but I can't find the Self contact  option.
    It says 'For Slave (SSID), select Self contact.'
    Where it could be ?
    That's what I see
    Altair Employee
    the tutorial is based on HW2020, where self contact is already available inside HyperMesh environment.
    In 2019.1 it should be used like you did, or using it as slave only.
    i've made a few modifications in your model, but essentially it was fine.
    I've run OS2019.2.2
    User: "LucaC"
    OP
    Updated by LucaC
    Thank you Adriano.
    I'm trying to run a different model using a set of loadcollector like yours. When I run the simulation, ig gives me that advice.
    *** ERROR # 4965 ***
     Maximum number of time increment cutbacks reached,
     analysis aborted.
     ANALYSIS COMPLETED.
     *** SOME ERRORS WERE REPORTED DURING THE RUN,
     *** PLEASE VERIFY RESULTS AS THEY MAY BE INVALID.
     *** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
    Altair Employee
    this error means convergency issue in your solution.
    It can be caused by some different causes.
    Try to run your model and include control card PARAM,NLMON,DISP.
    This will generate an additional H3D file showing what is happening at each increment, which might help you to identify where your issue is coming from.
    Additionally, there will be a more detailed .out file (name_nl.out) that gives you aditional information as well.
