1 - 4 of
41
Hello @mansour_ebrahim
To use the XML, you need to open a new process in rapidminer. After that, you need to go to View --> Show Panel --> XML present in the menu bar of rapdiminer. You need to copy the XML code provided in the above post and paste it in the XML window of rapidminer, then click the green tick mark on the XML window and you can see the process mention by rodrigo in your RM.
Thanks,
Varun
Thanks,
Varun
1 - 1 of
11
You may want to see the Annotate, the Extract Macro from Annotation operators.
I just made a few tests, nothing important but see this process:
Hope this helps,
Rodrigo.
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process" origin="GENERATED_TUTORIAL"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="retrieve" compatibility="9.2.001" expanded="true" height="68" name="Retrieve Iris" origin="GENERATED_TUTORIAL" width="90" x="45" y="34"> <parameter key="repository_entry" value="//Samples/data/Iris"/> </operator> <operator activated="true" class="multiply" compatibility="9.2.001" expanded="true" height="103" name="Multiply" width="90" x="179" y="34"/> <operator activated="true" class="annotations_to_data" compatibility="9.2.001" expanded="true" height="82" name="Annotations to Data" width="90" x="313" y="187"/> <operator activated="true" class="extract_macro_from_annotation" compatibility="9.2.001" expanded="true" height="68" name="Extract Macro from Annotation" origin="GENERATED_TUTORIAL" width="90" x="313" y="34"> <parameter key="extract_all" value="false"/> <parameter key="macro" value="Source"/> <parameter key="annotation" value="Source"/> <parameter key="fail_on_missing" value="true"/> </operator> <operator activated="true" class="generate_macro" compatibility="9.2.001" expanded="true" height="82" name="Generate Macro" width="90" x="447" y="34"> <list key="function_descriptions"> <parameter key="wat" value="replace(%{Source}, "data", "")"/> </list> </operator> <operator activated="true" class="print_to_console" compatibility="9.2.001" expanded="true" height="82" name="Print to Console" origin="GENERATED_TUTORIAL" width="90" x="581" y="34"> <parameter key="log_value" value="Source annotation is: %{wat}"/> </operator> <connect from_op="Retrieve Iris" from_port="output" to_op="Multiply" to_port="input"/> <connect from_op="Multiply" from_port="output 1" to_op="Extract Macro from Annotation" to_port="object"/> <connect from_op="Multiply" from_port="output 2" to_op="Annotations to Data" to_port="object"/> <connect from_op="Annotations to Data" from_port="annotations" to_port="result 2"/> <connect from_op="Extract Macro from Annotation" from_port="object" to_op="Generate Macro" to_port="through 1"/> <connect from_op="Generate Macro" from_port="through 1" to_op="Print to Console" to_port="through 1"/> <connect from_op="Print to Console" from_port="through 1" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="126"/> <portSpacing port="sink_result 3" spacing="0"/> </process> </operator> </process>
Rodrigo.
Rodrigo.
