🎉Community Raffle - Win $25
Join and Win
Walking Forward Testing
User: "Oprick"
New Altair Community Member
Updated by Jocelyn
Hello,
I built a multivariate regression forecasting using NN. Results seems to be ok so far.
However and since I'm forecasting the next value (+1) using all past values I would like to be able to test the model in a walk forward way, i.e. using past values to predict next in a rolling way till last example. I thought about using sliding window validation.
Each sliding window iteration produces one example only, because it is the prediction of next one. It seems to me that this is the right approach to get this kind of validation.
However I would like to visualize all iterations results appended to have something like this: https://3qeqpr26caki16dnhd19sv6by6v-wpengine.netdna-ssl.com/wp-content/uploads/2016/12/Sunspot-Dataset-Train-Test-Split.png
I though about collection and remember/recall operators, but with zero success.
Enclosed my mock process and data source.
Thanks for your help
1 - 6 of 61
    User: "hughesfleming68"
    Accepted Answer
    Updated by hughesfleming68
    Hi Oprick, you are correct to use the sliding window operator. Normally you would use the log operator to collect details about what is happening within the window. Looking at the train/test image, it looks like that because it is only showing where the data is split.
    Are you trying to overlay a sequence of predictions over actual data?
    User: "SGolbert"
    you can probably do what you want by using a combination of the Windowing operator and a normal Cross Validation:
    <?xml version="1.0" encoding="UTF-8"?><process version="9.2.001">
      <context>
        <input/>
        <output/>
        <macros/>
      </context>
      <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process">
        <parameter key="logverbosity" value="init"/>
        <parameter key="random_seed" value="2001"/>
        <parameter key="send_mail" value="never"/>
        <parameter key="notification_email" value=""/>
        <parameter key="process_duration_for_mail" value="30"/>
        <parameter key="encoding" value="SYSTEM"/>
        <process expanded="true">
          <operator activated="true" class="generate_data" compatibility="9.2.001" expanded="true" height="68" name="Generate Data" width="90" x="112" y="34">
            <parameter key="target_function" value="random"/>
            <parameter key="number_examples" value="1000"/>
            <parameter key="number_of_attributes" value="1"/>
            <parameter key="attributes_lower_bound" value="-10.0"/>
            <parameter key="attributes_upper_bound" value="10.0"/>
            <parameter key="gaussian_standard_deviation" value="10.0"/>
            <parameter key="largest_radius" value="10.0"/>
            <parameter key="use_local_random_seed" value="false"/>
            <parameter key="local_random_seed" value="1992"/>
            <parameter key="datamanagement" value="double_array"/>
            <parameter key="data_management" value="auto"/>
          </operator>
          <operator activated="true" class="time_series:windowing" compatibility="9.2.001" expanded="true" height="82" name="Windowing" width="90" x="380" y="34">
            <parameter key="attribute_filter_type" value="all"/>
            <parameter key="attribute" value=""/>
            <parameter key="attributes" value=""/>
            <parameter key="use_except_expression" value="false"/>
            <parameter key="value_type" value="nominal"/>
            <parameter key="use_value_type_exception" value="false"/>
            <parameter key="except_value_type" value="time"/>
            <parameter key="block_type" value="single_value"/>
            <parameter key="use_block_type_exception" value="false"/>
            <parameter key="except_block_type" value="value_matrix_row_start"/>
            <parameter key="invert_selection" value="false"/>
            <parameter key="include_special_attributes" value="false"/>
            <parameter key="has_indices" value="false"/>
            <parameter key="indices_attribute" value=""/>
            <parameter key="window_size" value="50"/>
            <parameter key="no_overlapping_windows" value="false"/>
            <parameter key="step_size" value="1"/>
            <parameter key="create_horizon_(labels)" value="true"/>
            <parameter key="horizon_attribute" value="att1"/>
            <parameter key="horizon_size" value="1"/>
            <parameter key="horizon_offset" value="0"/>
          </operator>
          <operator activated="true" class="concurrency:cross_validation" compatibility="8.2.000" expanded="true" height="145" name="Validation" width="90" x="648" y="34">
            <parameter key="split_on_batch_attribute" value="false"/>
            <parameter key="leave_one_out" value="false"/>
            <parameter key="number_of_folds" value="10"/>
            <parameter key="sampling_type" value="shuffled sampling"/>
            <parameter key="enable_parallel_execution" value="true"/>
              <operator activated="true" class="h2o:generalized_linear_model" compatibility="7.2.000" expanded="true" height="124" name="Generalized Linear Model" width="90" x="179" y="34">
                <parameter key="family" value="AUTO"/>
                <parameter key="link" value="family_default"/>
                <parameter key="solver" value="AUTO"/>
                <parameter key="reproducible" value="false"/>
                <parameter key="maximum_number_of_threads" value="4"/>
                <parameter key="use_regularization" value="true"/>
                <parameter key="lambda_search" value="false"/>
                <parameter key="number_of_lambdas" value="0"/>
                <parameter key="lambda_min_ratio" value="0.0"/>
                <parameter key="early_stopping" value="true"/>
                <parameter key="stopping_rounds" value="3"/>
                <parameter key="stopping_tolerance" value="0.001"/>
                <parameter key="standardize" value="true"/>
                <parameter key="non-negative_coefficients" value="false"/>
                <parameter key="add_intercept" value="true"/>
                <parameter key="compute_p-values" value="false"/>
                <parameter key="remove_collinear_columns" value="false"/>
                <parameter key="missing_values_handling" value="MeanImputation"/>
                <parameter key="max_iterations" value="0"/>
                <parameter key="specify_beta_constraints" value="false"/>
                <list key="beta_constraints"/>
                <parameter key="max_runtime_seconds" value="0"/>
                <list key="expert_parameters"/>
              </operator>
              <connect from_port="training set" to_op="Generalized Linear Model" to_port="training set"/>
              <connect from_op="Generalized Linear Model" from_port="model" to_port="model"/>
              <portSpacing port="source_training set" spacing="0"/>
              <portSpacing port="sink_model" spacing="0"/>
              <portSpacing port="sink_through 1" spacing="0"/>
              <description align="left" color="green" colored="true" height="113" resized="true" width="284" x="33" y="148">Builds a model on the current training data set (90 % of the data by default, 10 times).&lt;br&gt;&lt;br&gt;Make sure that you only put numerical attributes into a linear regression!</description>
            </process>
              <operator activated="true" class="apply_model" compatibility="9.2.001" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34">
                <parameter key="create_view" value="false"/>
              </operator>
              <operator activated="true" class="performance" compatibility="9.2.001" expanded="true" height="82" name="Performance" width="90" x="179" y="34">
                <parameter key="use_example_weights" value="true"/>
              </operator>
              <connect from_port="model" to_op="Apply Model" to_port="model"/>
              <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
              <connect from_op="Apply Model" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
              <connect from_op="Performance" from_port="performance" to_port="performance 1"/>
              <connect from_op="Performance" from_port="example set" to_port="test set results"/>
              <portSpacing port="source_model" spacing="0"/>
              <portSpacing port="source_test set" spacing="0"/>
              <portSpacing port="source_through 1" spacing="0"/>
              <portSpacing port="sink_test set results" spacing="0"/>
              <portSpacing port="sink_performance 1" spacing="0"/>
              <portSpacing port="sink_performance 2" spacing="0"/>
              <description align="left" color="blue" colored="true" height="107" resized="true" width="333" x="28" y="139">Applies the model built from the training data set on the current test set (10 % by default).&lt;br/&gt;The Performance operator calculates performance indicators and sends them to the operator result.</description>
            </process>
            <description align="center" color="transparent" colored="false" width="126">A cross validation including a linear regression.</description>
          </operator>
          <connect from_op="Generate Data" from_port="output" to_op="Windowing" to_port="example set"/>
          <connect from_op="Windowing" from_port="windowed example set" to_op="Validation" to_port="example set"/>
          <connect from_op="Validation" from_port="model" to_port="result 1"/>
          <connect from_op="Validation" from_port="test result set" to_port="result 2"/>
          <portSpacing port="sink_result 3" spacing="0"/>
        </process>
      </operator>
    </process>
    I couldn't find the Sliding Window Validation operator, I think it got replaced by Forecast Validation.
    You can also try replacing the neural network with a recurrent neural network, provided by the Add LSTM Layer operator of the Deep Learning extension. I am a beginner on the topic, so I can't give you any example yet, but I'm convinced that RNN are the way to go for time series.
    Regards,
    Sebastian
    @Oprick ...Looking at your process again and as @SGolbert suggested, you should take a look at the windowing operator. I do think on the other hand that you should stick with the value series extension. There are usage cases where both are necessary. The new time series operators don't completely replace the older extension.
    Kind regards,
    Alex
    User: "Oprick"
    OP
    Hi @hughesfleming68 I was looking at wrong direction. You pointed the correct way :)
    I used log family operators. I was not very familiar with that.
    Now I can overlap prediction_label and label.
    Enclosed the corrected process. I hope it helps someone else.
    Many Thanks
    Hi @Oprick, I saw how you set up your data. Basically you did manually what the windowing operator does in the beginning of your process. Give it a try the next time around as you could probably save yourself some steps. There are some other advantages as well with larger windows as you can use previous time steps as attributes.
    regards,
    Alex
    User: "Oprick"
    OP
    Hi @hughesfleming68
    Sure I will. Thanks for the tip  ;)
