Mining source code files
Hi there,
I'm new to the mining world and what I'm looking for is mining source code files, i.e files written in programming languages. I thought since source codes are textual data then I can find some text mining tool to mine them, and picked RapidMiner as it is one of the most famous text mining tools. Unfortunately, it couldn't read such files. Am I missing something here? do you have any advice on how to mine such files?
Many thanks
Many thanks
1 - 13 of
131
Hi,
you can search GitHub repos by language:
Whether you do it through web crawling or directly with the GitHub API, I leave it for you to find out
Regards,
Sebastian
Thany you @yyhuang and @SGolbert. Now I'm able to read the source code files I have. I also finished the RapidMiner tutorials which mainly used structured text files and got my head around it. However, since the source code files are unstructured textual data and what I'm looking for is analyzing some programming language features usage based on mining the files. Is there any advice/recommendations on the components/operators I should use considering that (1) the data is unstructured text (source code) and (2) I'm not going to analyze any natural language phrases and will skip the comments parts of the source code files. Thank you
Hi confusedMonMon,
Can you tell us what problem you are trying to solve? The approach will vary depending on that.
I think that in general you can work with the text mining extension. The Text and Web Mining Course is a great introduction, but AFIK it hasn't been made open yet (@Knut-RM). Depending on the complexity of the problem, you can build a good model by counting word frequencies and using n-grams.
Regards,
Sebastian
Hi,
Just wanted to mention that the text and web mining course is now public as well:
Hope this helps,
Ingo
Ingo
Thanks @SGolbert. I'm currently working on the text processing extension. I want to (1) exclude some sentences and paragraphs that start and/or end with a certain character (e.g. /*, //, #,...) from processing. Also, I want to (2) look for a predefined list of words and/or phrases that have a specific pattern in the documents to be detected and compared to others. Any suggestions to start with?
here is an example of the use of the Text Mining extension with the source code of two Python scripts:
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process">
<parameter key="logverbosity" value="init"/>
<parameter key="random_seed" value="2001"/>
<parameter key="send_mail" value="never"/>
<parameter key="notification_email" value=""/>
<parameter key="process_duration_for_mail" value="30"/>
<parameter key="encoding" value="SYSTEM"/>
<process expanded="true">
<operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document" width="90" x="112" y="34">
<parameter key="text" value="# Self Organizing Map # Importing the libraries import numpy as np import matplotlib.pyplot as plt import pandas as pd # Importing the dataset dataset = pd.read_csv('Credit_Card_Applications.csv') X = dataset.iloc[:, 1:-1].values y = dataset.iloc[:, -1].values # Feature Scaling from sklearn.preprocessing import MinMaxScaler sc = MinMaxScaler(feature_range = (0, 1)) X = sc.fit_transform(X) # Training the SOM from minisom import MiniSom som = MiniSom(x = 10, y = 10, input_len = 14, sigma = 1.0, learning_rate = 0.5) som.random_weights_init(X) som.train_random(data = X, num_iteration = 200) # Visualizing the results from pylab import bone, pcolor, colorbar, plot, show bone() pcolor(som.distance_map().T) colorbar() markers = ['o', 's'] colors = ['r', 'g'] for i, x in enumerate(X): w = som.winner(x) plot(w[0] + 0.5, w[1] + 0.5, markers[y[i]], markeredgecolor = colors[y[i]], markerfacecolor = 'None', markersize = 10, markeredgewidth = 2) show() # Finding the frauds mappings = som.win_map(X) frauds = np.concatenate((mappings[(8,1)], mappings[(6,8)]), axis = 0) frauds = sc.inverse_transform(frauds)"/>
<parameter key="add label" value="false"/>
<parameter key="label_type" value="nominal"/>
</operator>
<operator activated="true" class="text:create_document" compatibility="8.1.000" expanded="true" height="68" name="Create Document (2)" width="90" x="112" y="187">
<parameter key="text" value="# Recurrent Neural Network # Part 1 - Data Preprocessing # Importing the libraries import numpy as np import matplotlib.pyplot as plt import pandas as pd # Importing the training set dataset_train = pd.read_csv('Google_Stock_Price_Train.csv') training_set = dataset_train.iloc[:, 1:2].values # Feature Scaling from sklearn.preprocessing import MinMaxScaler sc = MinMaxScaler(feature_range = (0, 1)) training_set_scaled = sc.fit_transform(training_set) # Creating a data structure with 60 timesteps and 1 output X_train = [] y_train = [] for i in range(60, 1258): X_train.append(training_set_scaled[i-60:i, 0]) y_train.append(training_set_scaled[i, 0]) X_train, y_train = np.array(X_train), np.array(y_train) # Reshaping X_train = np.reshape(X_train, (X_train.shape[0], X_train.shape[1], 1)) # The last "1" corresponds to the number of dataset, for example to include # another related stock in the predictions # Part 2 - Building the RNN # Importing the Keras libraries and packages from keras.models import Sequential from keras.layers import Dense from keras.layers import LSTM from keras.layers import Dropout # Initialising the RNN regressor = Sequential() # Adding the first LSTM layer and some Dropout regularisation regressor.add(LSTM(units = 50, return_sequences = True, input_shape = (X_train.shape[1], 1))) regressor.add(Dropout(0.2)) # Adding a second LSTM layer and some Dropout regularisation regressor.add(LSTM(units = 50, return_sequences = True)) regressor.add(Dropout(0.2)) # Adding a third LSTM layer and some Dropout regularisation regressor.add(LSTM(units = 50, return_sequences = True)) regressor.add(Dropout(0.2)) # Adding a fourth LSTM layer and some Dropout regularisation regressor.add(LSTM(units = 50)) regressor.add(Dropout(0.2)) # Adding the output layer regressor.add(Dense(units = 1)) # Compiling the RNN regressor.compile(optimizer = 'adam', loss = 'mean_squared_error') # Regression problem # Fitting the RNN to the Training set regressor.fit(X_train, y_train, epochs = 100, batch_size = 32) # Part 3 - Making the predictions and visualising the results # Getting the real stock price of 2017 dataset_test = pd.read_csv('Google_Stock_Price_Test.csv') real_stock_price = dataset_test.iloc[:, 1:2].values # Getting the predicted stock price of 2017 dataset_total = pd.concat((dataset_train['Open'], dataset_test['Open']), axis = 0) inputs = dataset_total[len(dataset_total) - len(dataset_test) - 60:].values inputs = inputs.reshape(-1,1) inputs = sc.transform(inputs) X_test = [] for i in range(60, 80): X_test.append(inputs[i-60:i, 0]) X_test = np.array(X_test) X_test = np.reshape(X_test, (X_test.shape[0], X_test.shape[1], 1)) predicted_stock_price = regressor.predict(X_test) predicted_stock_price = sc.inverse_transform(predicted_stock_price) # undo normalization # Visualising the results plt.plot(real_stock_price, color = 'red', label = 'Real Google Stock Price') plt.plot(predicted_stock_price, color = 'blue', label = 'Predicted Google Stock Price') plt.title('Google Stock Price Prediction') plt.xlabel('Time') plt.ylabel('Google Stock Price') plt.legend() plt.show() "/>
</operator>
<operator activated="true" class="collect" compatibility="9.2.001" expanded="true" height="103" name="Collect" width="90" x="246" y="34">
<parameter key="unfold" value="false"/>
</operator>
<operator activated="true" class="loop_collection" compatibility="9.2.001" expanded="true" height="82" name="Loop Collection" width="90" x="447" y="34">
<parameter key="set_iteration_macro" value="false"/>
<parameter key="macro_name" value="iteration"/>
<parameter key="macro_start_value" value="1"/>
<operator activated="true" class="text:remove_document_parts" compatibility="8.1.000" expanded="true" height="68" name="Remove Document Parts" width="90" x="380" y="34">
<parameter key="deletion_regex" value="#(.*?)\n"/>
</operator>
<connect from_port="single" to_op="Remove Document Parts" to_port="document"/>
<connect from_op="Remove Document Parts" from_port="document" to_port="output 1"/>
<portSpacing port="source_single" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<description align="center" color="transparent" colored="false" width="126">remove comments</description>
</operator>
<operator activated="true" class="text:process_documents" compatibility="8.1.000" expanded="true" height="103" name="Process Documents" width="90" x="648" y="34">
<parameter key="create_word_vector" value="true"/>
<parameter key="vector_creation" value="Term Frequency"/>
<parameter key="add_meta_information" value="true"/>
<parameter key="keep_text" value="false"/>
<parameter key="prune_method" value="none"/>
<parameter key="prune_below_percent" value="3.0"/>
<parameter key="prune_above_percent" value="30.0"/>
<parameter key="prune_below_rank" value="0.05"/>
<parameter key="prune_above_rank" value="0.95"/>
<parameter key="datamanagement" value="double_sparse_array"/>
<parameter key="data_management" value="auto"/>
<operator activated="true" class="text:tokenize" compatibility="8.1.000" expanded="true" height="68" name="Tokenize" width="90" x="112" y="34">
<parameter key="mode" value="non letters"/>
<parameter key="characters" value=".:"/>
<parameter key="language" value="English"/>
<parameter key="max_token_length" value="3"/>
</operator>
<operator activated="true" class="text:generate_n_grams_terms" compatibility="8.1.000" expanded="true" height="68" name="Generate n-Grams (Terms)" width="90" x="447" y="34">
<parameter key="max_length" value="2"/>
</operator>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Generate n-Grams (Terms)" to_port="document"/>
<connect from_op="Generate n-Grams (Terms)" from_port="document" to_port="document 1"/>
<portSpacing port="source_document" spacing="0"/>
<portSpacing port="sink_document 1" spacing="0"/>
<portSpacing port="sink_document 2" spacing="0"/>
</process>
<description align="center" color="transparent" colored="false" width="126">tokenize, do n-grams and count frequencies<br/></description>
</operator>
<connect from_op="Create Document" from_port="output" to_op="Collect" to_port="input 1"/>
<connect from_op="Create Document (2)" from_port="output" to_op="Collect" to_port="input 2"/>
<connect from_op="Collect" from_port="collection" to_op="Loop Collection" to_port="collection"/>
<connect from_op="Loop Collection" from_port="output 1" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="example set" to_port="result 1"/>
</process>
</operator>
</process>
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
</operator>
</process>
You would have to work quite a bit in the subprocess of the Process Documents operator to get something useful.
Regards,
Sebastian
hi @confusedMonMon I think @SGolbert meant to say the "Text Processing" extension. I make the same mistake all the time.
Hi @SGolbert . I have a further question. How to set the text directories in Process Documents from Files operator automatically instead of manually? Is there any way to do so? This is my attempt:
<br>
I cannot parse your process, can you paste it again with the right format?
Regards,
Sebastian
Thanks @SGolbert I managed to make it work now.
1 - 2 of
21
Hi @confusedMonMon,
if you have source codes files, saying .sql, .c, .py files, you would need to read document operator from text processing extension.
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.001"> <context> <input/> <output/> <macros/> </context> <operator activated="true" class="process" compatibility="9.2.001" expanded="true" name="Process"> <parameter key="logverbosity" value="init"/> <parameter key="random_seed" value="2001"/> <parameter key="send_mail" value="never"/> <parameter key="notification_email" value=""/> <parameter key="process_duration_for_mail" value="30"/> <parameter key="encoding" value="SYSTEM"/> <process expanded="true"> <operator activated="true" class="open_file" compatibility="9.2.001" expanded="true" height="68" name="Open File" width="90" x="112" y="34"> <parameter key="resource_type" value="URL"/> <parameter key="url" value="https://raw.githubusercontent.com/Marcnuth/AnomalyDetection/master/anomaly_detection/anomaly_detect_vec.py"/> </operator> <operator activated="true" class="text:read_document" compatibility="8.1.000" expanded="true" height="68" name="Read Document" width="90" x="380" y="34"> <parameter key="extract_text_only" value="true"/> <parameter key="use_file_extension_as_type" value="true"/> <parameter key="content_type" value="txt"/> <parameter key="encoding" value="SYSTEM"/> </operator> <connect from_op="Open File" from_port="file" to_op="Read Document" to_port="file"/> <connect from_op="Read Document" from_port="output" to_port="result 1"/> <portSpacing port="source_input 1" spacing="0"/> <portSpacing port="sink_result 1" spacing="0"/> <portSpacing port="sink_result 2" spacing="0"/> </process> </operator> </process>
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
</operator>
</process>
<context>
<input/>
<output/>
<macros/>
</context>
</operator>
</operator>
</operator>
</operator>
</process>
</operator>
</operator>
</operator>
</process>
</operator>
</process>
</operator>
</process>
Regards,
Sebastian
