🎉Community Raffle - Win $25
Join and Win
Coil Loss homogenized
User: "Wenjun Zhu"
Altair Community Member
Updated by Wenjun Zhu
Hi, I am trying to use the coil loss tool.  But when solving the project, it requires me to close the project. Could you help?
1 - 3 of 31
    User: "SimonGuicheteau"
    Altair Employee
    Updated by SimonGuicheteau
    Hello,
    the warning in yellow is probably due to some windows being opened while doing something else. Like If you keep the window to edit the region open and try to solve, the window is not synchronous. Everything should be greyed out as you will be in solved state.
    If everything else is correct and the project is solved then this is it, just close the Edit windows before solving.
    Cheers
    User: "Wenjun Zhu"
    OP
    Hello,
    Cheers
    Thank you. but I confirm that the Edit windows all closed.
    If I set to "not compute the coil loss", then the project is all OK.
    lost....
    Altair Employee
    lost....
    Sorry for the confusion I thought the main error was the warning. I understand then that it does not solve.
    I guess the coil model with losses needs to run Flux servers as submodels. Can you chek the Flux servers are enabled ? Do you have a green light on Distribution manager from the Flux supervisor ?
    If no, run the supervisor in admin mode and click on Distributiuon manager, it should run a batch script that resets it
