How do I create a heat flux from a csv file in Optistruct?
Alvaro Rodriguez_20950
Alvaro Rodriguez_20950 Altair Community Member
edited August 2023 in Community Q&A
Hello, I started using hypermesh recently for my thesis and I want to perform an structural optimization on a wing. For that I want to include the heat flux that enters the wing, which is calculated externally and stored in a csv file. In the documentation is stated that the flux panel from analysis can import csv files, but I am not given the option: image
I do not know what is the problem, or if I have to define something previously. I have already imported a pressure profile in another csv file and it work fine so I have no clue.
I attach the page of the documentation I read: https://help.altair.com/hwdesktop/hm/topics/panels/help086.htm
Alvaro
Best Answer
  • Brian_20847
    Brian_20847 Altair Community Member
    edited August 2023 Answer ✓
    Hi Alvaro,
    You can import .csv file through the field tool.
    Thanks
Answers
  • Brian_20847
    Hi Alvaro,
    Thanks
  • Alvaro Rodriguez_20950
    edited August 2023
    Hi Alvaro,
    Thanks
    Hi Brian,
    You just saved my thesis, thank you very much!
Welcome!
Welcome!
