🎉Community Raffle - Win $25
Join and Win
How to limit the number of email documents received from the Read Documents (Email) operator
User: "rileye"
New Altair Community Member
Updated by Jocelyn
I'm trying to find a way to limit the number of email documents (either by a count or email date) when using the Read Documents-Email operator.
1 - 2 of 21
    User: "IngoRM"
    Accepted Answer
    Hi @rileye ,
    Welcome to the forum.  I am afraid that this is not possible since this kind of limit does not seem to be supported by the Java Mail standard we are using for this operator.  So the only option for this would be to regularly fetch the emails from the source and store them in some kind of DWH and fetch only the desired amount or date range from there.  If anybody sees a different solution, please chime in.
    Hope this helps,
    Ingo
    User: "sgenzer"
    Altair Employee
    yes if it were me I would investigate using Zapier...it's likely you could rig up something there that you could then send to RapidMiner.
