🎉Community Raffle - Win $25
Join and Win
Difficulties with macro value in scientific notation
User: "lionelderkrikor"
New Altair Community Member
Updated by Jocelyn
Hi all,
RapidMiner raises an error when a macro value is in scientific notation:
The macro value is well recorded ...:
...and is used in an operator :
Is there a solution / workaround to this ?
Thanks for your explanations...
Regards,
Lionel
NB : The process :
<?xml version="1.0" encoding="UTF-8"?><process version="9.2.000-SNAPSHOT">
  <context>
    <input/>
    <output/>
    <macros/>
  </context>
  <operator activated="true" class="process" compatibility="9.2.000-SNAPSHOT" expanded="true" name="Process">
    <parameter key="logverbosity" value="init"/>
    <parameter key="random_seed" value="2001"/>
    <parameter key="send_mail" value="never"/>
    <parameter key="notification_email" value=""/>
    <parameter key="process_duration_for_mail" value="30"/>
    <parameter key="encoding" value="SYSTEM"/>
    <process expanded="true">
      <operator activated="true" class="operator_toolbox:create_exampleset" compatibility="1.7.000" expanded="true" height="68" name="Create ExampleSet" width="90" x="45" y="34">
        <parameter key="generator_type" value="date_series"/>
        <parameter key="number_of_examples" value="100"/>
        <parameter key="use_stepsize" value="true"/>
        <list key="function_descriptions"/>
        <parameter key="add_id_attribute" value="false"/>
        <list key="numeric_series_configuration"/>
        <list key="date_series_configuration"/>
        <list key="date_series_configuration (interval)">
          <parameter key="date" value="2019-01-01 00:00:00.1.hour"/>
        </list>
        <parameter key="date_format" value="yyyy-MM-dd HH:mm:ss"/>
        <parameter key="column_separator" value=","/>
        <parameter key="parse_all_as_nominal" value="false"/>
        <parameter key="decimal_point_character" value="."/>
        <parameter key="trim_attribute_names" value="true"/>
      </operator>
      <operator activated="true" class="generate_id" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Generate ID" width="90" x="179" y="34">
        <parameter key="create_nominal_ids" value="false"/>
        <parameter key="offset" value="0"/>
      </operator>
      <operator activated="true" class="generate_data" compatibility="9.2.000-SNAPSHOT" expanded="true" height="68" name="Generate Data" width="90" x="45" y="136">
        <parameter key="target_function" value="random"/>
        <parameter key="number_examples" value="100"/>
        <parameter key="number_of_attributes" value="2"/>
        <parameter key="attributes_lower_bound" value="-10.0"/>
        <parameter key="attributes_upper_bound" value="10.0"/>
        <parameter key="gaussian_standard_deviation" value="10.0"/>
        <parameter key="largest_radius" value="10.0"/>
        <parameter key="use_local_random_seed" value="false"/>
        <parameter key="local_random_seed" value="1992"/>
        <parameter key="datamanagement" value="double_array"/>
        <parameter key="data_management" value="auto"/>
      </operator>
      <operator activated="true" class="generate_id" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Generate ID (2)" width="90" x="179" y="136">
      </operator>
      <operator activated="true" breakpoints="after" class="concurrency:join" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Join" width="90" x="313" y="85">
        <parameter key="remove_double_attributes" value="true"/>
        <parameter key="join_type" value="inner"/>
        <parameter key="use_id_attribute_as_key" value="true"/>
        <list key="key_attributes"/>
        <parameter key="keep_both_join_attributes" value="false"/>
      </operator>
      <operator activated="true" class="extract_macro" compatibility="9.2.000-SNAPSHOT" expanded="true" height="68" name="Extract Macro" width="90" x="447" y="85">
        <parameter key="macro" value="dateOffset"/>
        <parameter key="macro_type" value="data_value"/>
        <parameter key="statistics" value="average"/>
        <parameter key="attribute_name" value="date"/>
        <parameter key="example_index" value="1"/>
        <list key="additional_macros"/>
      </operator>
      <operator activated="true" class="generate_macro" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Generate Macro" width="90" x="581" y="85">
        <list key="function_descriptions">
          <parameter key="dateDiffOffset" value="date_diff(date_parse(&quot;01/01/1970&quot;),date_parse(%{dateOffset}))"/>
        </list>
      </operator>
      <operator activated="true" breakpoints="after" class="date_to_numerical" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Date to Numerical" width="90" x="715" y="85">
        <parameter key="time_unit" value="day"/>
        <parameter key="millisecond_relative_to" value="second"/>
        <parameter key="second_relative_to" value="minute"/>
        <parameter key="minute_relative_to" value="hour"/>
        <parameter key="hour_relative_to" value="day"/>
        <parameter key="day_relative_to" value="month"/>
        <parameter key="week_relative_to" value="year"/>
        <parameter key="month_relative_to" value="year"/>
        <parameter key="quarter_relative_to" value="year"/>
        <parameter key="half_year_relative_to" value="year"/>
        <parameter key="year_relative_to" value="era"/>
        <parameter key="keep_old_attribute" value="false"/>
      </operator>
      <operator activated="true" class="aggregate" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Aggregate" width="90" x="849" y="34">
        <parameter key="use_default_aggregation" value="false"/>
        <parameter key="attribute_filter_type" value="all"/>
        <parameter key="attribute" value=""/>
        <parameter key="attributes" value=""/>
        <parameter key="use_except_expression" value="false"/>
        <parameter key="value_type" value="attribute_value"/>
        <parameter key="use_value_type_exception" value="false"/>
        <parameter key="except_value_type" value="time"/>
        <parameter key="block_type" value="attribute_block"/>
        <parameter key="use_block_type_exception" value="false"/>
        <parameter key="except_block_type" value="value_matrix_row_start"/>
        <parameter key="invert_selection" value="false"/>
        <parameter key="include_special_attributes" value="false"/>
        <parameter key="default_aggregation_function" value="average"/>
        <list key="aggregation_attributes">
          <parameter key="att1" value="average"/>
        </list>
        <parameter key="group_by_attributes" value="date"/>
        <parameter key="count_all_combinations" value="false"/>
        <parameter key="only_distinct" value="false"/>
        <parameter key="ignore_missings" value="true"/>
      </operator>
      <operator activated="true" class="numerical_to_date" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Numerical to Date" width="90" x="1117" y="34">
        <parameter key="time_offset" value="%{dateDiffOffset}"/>
      </operator>
      <operator activated="true" class="concurrency:join" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Join (2)" width="90" x="1275" y="85">
        <parameter key="use_id_attribute_as_key" value="false"/>
        <list key="key_attributes">
          <parameter key="date" value="date"/>
        </list>
      </operator>
      <operator activated="true" class="set_role" compatibility="9.2.000-SNAPSHOT" expanded="true" height="82" name="Set Role" width="90" x="1448" y="85">
        <parameter key="target_role" value="id"/>
        <list key="set_additional_roles"/>
      </operator>
      <connect from_op="Create ExampleSet" from_port="output" to_op="Generate ID" to_port="example set input"/>
      <connect from_op="Generate ID" from_port="example set output" to_op="Join" to_port="left"/>
      <connect from_op="Generate Data" from_port="output" to_op="Generate ID (2)" to_port="example set input"/>
      <connect from_op="Generate ID (2)" from_port="example set output" to_op="Join" to_port="right"/>
      <connect from_op="Join" from_port="join" to_op="Extract Macro" to_port="example set"/>
      <connect from_op="Extract Macro" from_port="example set" to_op="Generate Macro" to_port="through 1"/>
      <connect from_op="Generate Macro" from_port="through 1" to_op="Date to Numerical" to_port="example set input"/>
      <connect from_op="Date to Numerical" from_port="example set output" to_op="Aggregate" to_port="example set input"/>
      <connect from_op="Date to Numerical" from_port="original" to_op="Join (2)" to_port="left"/>
      <connect from_op="Aggregate" from_port="example set output" to_op="Numerical to Date" to_port="example set input"/>
      <connect from_op="Numerical to Date" from_port="example set output" to_op="Join (2)" to_port="right"/>
      <connect from_op="Join (2)" from_port="join" to_op="Set Role" to_port="example set input"/>
      <connect from_op="Set Role" from_port="example set output" to_port="result 1"/>
    </process>
  </operator>
</process>
