Filtering ALL Examples (no. of missing data in the attribute = total no. of examples)
User: "1705410G"
New Altair Community Member
Updated by Jocelyn
I would like to filter out all missing data. Where the number of missing data in the attribute is equal to the total number of examples.
I know Select Attribute can do the trick. However, as I have roughly 20-30 attributes where all examples missing, so I would not like to pick it out individually.
I've tried using Filter Examples > no_missing_attributes, but I have no idea why I ended up with no examples at all from 2041 examples.
Thank you!
regards,
AY
1 - 12 of 121
    User: "lionelderkrikor"
    Hi @1705410G,
    Could you share your dataset and eventually your process ?
    Regards,
    Lionel
    User: "1705410G"
    OP
    Updated by 1705410G
    NIL - Sorry, had to remove due to privacy.
    Accepted Answer
    Hi again @1705410G,
    A solution is to use Remove Useless Attributes operator...
    Hope it helps,
    Regards,
    Lionel
    User: "1705410G"
    OP
    Updated by 1705410G
    lionelderkrikor
    I'm not sure if this is the correct way to share a process. I achieve 0 examples after running this process when I only want to remove those attributes with ALL missing examples.
    Regards,
    AY
    Hi again @1705410G,
    Hope it helps,
    Regards,
    Lionel
    User: "1705410G"
    OP
    @ lionelderkrikor
    Thank you!!
    Regards,
    AY
    User: "tftemme"
    Hi @1705410G,
    Another solution is the operator Filter Attributes with Missing Values from the Operator Toolbox extension (which exactly does what you want and has further configurations to remove Attributes with Missing Values). The reason that you end up with 0 Examples when using Filter Examples is that the operator removes examples for which the attribute selected is missing. So as your attribute you actually want to remove has only missing values, all Examples are removed.
    Best regards,
    Fabian
    User: "1705410G"
    OP
    @ lionelderkrikor ,
    What parameters should I set in Remove Useless Attributes then? Or should I leave it ? I read it briefly but i'm unsure how it works.
    Regards,
    AY
    User: "1705410G"
    OP
    @ lionelderkrikor ,
    What parameters should I set in Remove Useless Attributes then? Or should I leave it ? I read it briefly but I don't understand how it works.
    Regards,
    AY
    User: "1705410G"
    OP
    @ lionelderkrikor ,
    What parameters should I set it too? I read it up briefly but am unsure how it works.
    Regards,
    AY
    User: "1705410G"
    OP
    @ lionelderkrikor ,
    Regards,
    AY
    User: "Telcontar120"
    You can leave the default settings and it should eliminate any constant attributes.  Try running that and see if it gives you the results you are expecting.  If you then want to set a lower threshold then you can modify the min deviation for numericals or nominals.
