segmentation error
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
hi,
when iam running a script , frequently iam facing segmentation error. what might be the possibilities .
regards,
jamie
1 - 12 of 121
    User: "tinh"
    Altair Community Member
    Updated by tinh
    Hi Jamie
    it is due to some of commands are sensitive to make appcrash
    Altair Employee
    OP
    Hi Jamie
    so tinh how can i overcome that...or what changes should i make
    User: "tinh"
    Updated by tinh
    Hi Jamie,
    You have to detect which command is output to command.tcl last? then the next command in your script is sensitive.
    Please show us a range of your codes around that command
    Altair Employee
    OP
    TINH. actually ,once the tk message is displayed (highlited in the scripr).i get the segmentation error.
    User: "tinh"
    Updated by tinh
    Hi Jamie,
    the error appeared after you clicked on OK button of the message box, didn't it?
    Altair Employee
    OP
    Hi Jamie,
    yes tinh
    and the the exported file is not in proper format.
    Altair Employee
    OP
    hey tinh..just now i removed that tk message..now its working..but how come tinh?
    User: "tinh"
    Updated by tinh
    I see it calls proc napocomparison after clicking ok
    could you show that proc?
    Altair Employee
    OP
    <?xml version="1.0" encoding="UTF-8"?>napo1.thumb.PNG.753a47d93d4f69df901c348236e122a6.PNG
    User: "tinh"
    Updated by tinh
    Hi Jamie,
    the sensitive command is *findmark
    I think the bit must not be 257
    could you shift f5 and find some elems attached to some nodes then check what number is output to command.tcl?
    as i remember, it is 1 or 0
    Altair Employee
    OP
    Hi Jamie,
    tinh ,i dont find any difference in that command.
    tinh ..anyway the commands above the findmark itself are not excuted.
    Altair Employee
    OP
    Hi Jamie,
    HEY TINH .got the issue solved.....There was  was no *createstringarray before the feinputwithdata command
